Old 01-11-2013   #41
cvette98pacecar
Default Re: What projects or modifications do you have planned in 2013?
Originally Posted by sammy View Post
robert , hi yes i switched to coreys headers @ bill boudreaus on the way home . i gave him the headers to sell on his site ./ i need to switch out the brembos .we did a temp fix on the rotors and hats but it wont last long . times are tough trying to come up with the funds to put either stk brakes or c5 conversions on . the rotors and hats are toast but will want to sell the calipers once i do .
I will give Corey a call on the Headers, When you are ready to sell the Calipers let me know.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 01-12-2013   #42
Jagdpanzer
Jagdpanzer's Avatar
Finishing the 402 build.
Made a bit of progress over the Holidays.
Bryant 4.00" LT5 stroker cranshaft all prepped and ready to go in:
With the longer stroke crank had to notch the block some to allow the rods to clear:
Cylinder liners installed and deckplate honed, ready for the crankshaft to go in:
Crankshaft installed, Permabond A136 sealant layed down:
Lower housing installed and torqued down to specs:
Crankshaft end play checked:
Now ready for the rods & pistons to go in.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-12-2013   #43
Those torque angle meters are horrible took 3 of them to finish my build....
Old 01-12-2013   #44
Fully Vetted
Fully Vetted's Avatar
I'm curious what kind of power you're expecting when this monster is complete? Is it going to be NA or are any power adders planned (as if they were needed)?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 01-12-2013   #45
Jagdpanzer
Jagdpanzer's Avatar
Originally Posted by Fully Vetted View Post
I'm curious what kind of power you're expecting?
I'll be happy with a fat torque curve and a solid 500 hp at the wheels.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-12-2013   #46
HAWAIIZR-1's Avatar
Wow, Phil that sounds and looks awesome. I wish I could get a hold of the 90 for sale in Hawaii (dealer wants too much and the car is a trashed beyond restoration) that I want to use as a parts car then I would want to build another motor like this. Thanks for sharing. Craig
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 01-12-2013   #47
Hog
Here are some specs from a 1990 ZR-1 that is currently for sale at Lingenfelter. The 402 LT5 was built at Lingenfelter PE in 1998. Thought you may be interested in the dyno numbers.
LPE 402 CID LT5 Engine
623 crankshaft horsepower
540 crankshaft torque
492 rear wheel horsepower
441 rear wheel torque
JE Forged Pistons
Forged LT5 crankshaft
LPE steel cylinder liners
LPE Ported LT5 cylinder heads
LPE Titanium valve spring retainers
LPE Stainless steel intake & exhaust valves
LPE ZR1 intake & exhaust camshafts
LPE ZR1 long tube headers
Borla stainless steel exhaust system
Upgraded brakes
Roll bar
Fikse forged 17" three peice custom wheels
27540ZR17 / 31535ZR17 tires *
Your 402 is gonna be a very fun ride.
peace
Hog
Old 01-18-2013   #48
HAWAIIZR-1's Avatar
Hey folks, I thought it was time to share what we all have planned for our Zs in 2013. I'm on my arse and was supposed to do some of these in 2012, but somehow other priorities too precedence and it never happened. Some of my plans are dependent on if I am moving back to Hawaii in a few months, but none the less, here are my plans:
1. Remove power antenna and install tune trapper stealth unit under rear tray; plug hole for now until I can shave hole with new paint job (on the shelf, need to find plug and paint)
2. HID headlight conversion (on the shelf)
3. Install DRM coilover suspension with new FX3 shocks and Banski complete C4 rear kits (waiting for DRM kit, Carter brackets, and Banski set-up)
4. Install C5 mirrors (on the shelf and already painted color matched)
5. Replace steering wheel with Momo competition and install NRG hub quick release/lock (on the shelf)
6. Make Christmas wreath for next year out of stock steering wheel once removed (XMas 2013)
7. Put SW headers back on and install new SW X pipe w/Dynomax Ultraflo 17220 (single 3" in/out) and Pypes Challenger tips (on the shelf)
8. Autometer dual gauge pillar mount with wide band A/F and fuel pressure gauges (have mount, need gauges)
9. Repair/replace two front speakers that are not working
Just an updated to add 2 more items that I just ordered today from www.vette2vette.com:
10. 86-96 C4 No Flex Frame Stiffener Bar System
11. 90-93 Steering Column Housing Support w/new pivot pins
I added the oversized pins to the column last year, but it is not doing the trick and I'm not happy about the movement. I also want to stiffen up the chassis if possible and another while I'm at it install when I do the coilovers, etc.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 01-19-2013   #49
RICKYRJ1
RICKYRJ1's Avatar
I feel to really maximize the total performance of that engine build it will need to be deployed into the proper car. I have done some extensive research and all the data points to a 95 black ZR-1 in NJ. I'll put you in contact with the owner (real nice guy!) Thanks for the engine porn
Old 01-19-2013   #50
JE Forged Pistons
Upgraded brakes
Roll bar
peace
Hog
Had me drooling...right up to the part about the exhaust system. Unless Borla has come up with a higher flow system than what was on my 350 LT5. No resonance, but things like the twin tubes in the resonator being less than 2" in diameter, in and out, and the muffs with similar restrictions.
For that kind of HP, you might want to think about a 3" system, e.g., the Watson or SW headers w/ 1-7/8 - 2" primaries (respectively), the 3" SW X-pipe, and the Dynamax 3" in/twin 2" outlet muffs and either a vacuum or an electric "flapper".
For the 350-368 LT5s, Mark has good things to say about Corsa. However, applicability to a big inch LT5 gives me pause, as the FBI gang seems to favor the (above) mentioned scenario for the big inch motors (e.g.,Bob G; 427, Kevin C; 441, Al D; 441, Dominic S; "500" pkg 350, my "500" pkg 350 (soon as I can get over to Al's to have the muffs installed)
Just a thought.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
