#41 |
![]() Join Date: Dec 2003
It's a pull-release clutch, not a push-release, hence the "ball" surface on the underside of the pivot, where the load is.
#42 | |
![]() Join Date: Dec 2012
Lance...red/red 1991 0682 |
#43 |
![]() Join Date: Apr 2007
I was looking at Marc Haibeck's website and saw he has a clutch fork failure mentioned, but it broke at a different point due to lack of lubrication. So I am not sure what will show when we are looking at a fork to anticipate possible failure. Here is what he showed and said :
![]() This fork broke because it was subjected to high load during many clutch release cycles. It was used with an OE type Valeo pressure plate.
The root cause was lack of lubrication on the pivot ball. The pivot ball was dry with no lubricant. The pedal force required to release the clutch was about twice the normal amount. With a new fork and a lubricated pivot ball the pedal force to release the clutch returned to normal. The correct pivot ball lubricant has a molybdenum disulfide high pressure anti-friction additive. The pivot ball should be freshly lubricated when a new clutch is installed. The tips that engage with the throw out bearing should also be lubricated.
#44 |
Interesting that it broke along what may be a forming score line.....
#45 | |
![]() Join Date: Aug 2006
May I sit in your car and reminise? I'll be back in 1991! |
#46 |
Virtually all fatigue breaks occur at stress risers, i.e. nicks, scratches, sharp corners, tooling marks, etc. That's why parts designed to shear at specific axial load pressures are polished.
This get me to thinking about "weak links." The cause of fork failure sure points to excessive pivot friction. if the clutch fork was strengthened and excessive pedal pressure ignored, eventually the pivot would break or wear to the point the fork would come off the pivot. I'm not sure what exactly might happen, but it could be much more catastrophic if the fork got tangled up in there. The moral of the story is check the pivot, check fork, replace if worn and lubricate always.
