12-21-2012 | #41 |
Re: 4-7 firing issue; posting for a member
As stated in my first post, I would start with Dark Blue wire off the bottom of the DIS Circuit 932.....its the one wire that is isolated to 4-7 in the factory manual.
12-21-2012 | #42 | |
"Fortunately you can do end to end wire tests on the harness that runs to the coil from the DIS." But since there's no points or score keeper, eh... doesn't matter.
12-21-2012 | #43 |
Having a 90, and not wanting to muddy the water with a possible irrelevancy, I've kept to just lurking up to now. But, now I have an observation and a question:
Out of curiosity, I took direct measurements of the primary and secondary windings of a set of AC/Delco ignition coils and was surprised to see two of them read open on the secondary (spark) side. However, the other two read 5.682kΩ and 5.590kΩ. However, the primary resistance was .4xΩ for all 4 of them. The thing is, I changed the coils as a matter of routine at about 35800 miles as part of a starter and ignition R&R project. Up to then the coils seemed to be working OK. I recon I'd not put the "open" coils back in service, but curious what others may have experienced when measuring resistance across the secondary (SPARK) terminals? Another thing... At the risk of that irrelevancy I mentioned, my ('90 FSM) shows an individual driver circuit for each coil, mounted to the coil module. Is that also the case with 91+ coil modules? If so, then the driver for that coil needs to be considered (in turn) and we can get to that. But, first is there a dedicated driver (ganged or descrete) mounted on the coil mod? BTW, pulling the plenum is a right of passage for a ZR-1 owner. Might as well get that one out of the way! P.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 12-21-2012 at 03:15 PM. Reason: spelling |
12-21-2012 | #44 |
Paul, I believe the "solid state driver" shown (4 of them) in the FSM to
be an error. The only drivers I know of are in the DIS. As for the "open" measurement on the coils that work try using a 10k ohm resistor in series. I suspect you DVM is not handling the inductive kick from the coil very well. Or set up 100k rheostat in series with the meter and the coil then turn the 100k down to 0k. The reading then will be the coil resistance.
12-21-2012 | #45 | ||
But, the coils with an "open" reading were working at the time they were removed. However, being the "open" appeared on the secondary (read: high voltage) side, it isn't too hard to imagine if there was a tiny break in the internal connection or solder joint between the winding and the spark wire post, it is conceivable the voltage would be high enough to jump the breach anyway. (The coil is firing two plugs at the same time, so what's one more gap - more or less? High voltage introduces a whole nother aspect to troubleshooting. Saw a poor Navy Firecontrol striker dude lean past an open high voltage slip ring pin fitting (that had who knows what open loop voltage was on it!) and drew an arc about 8 inches long to the side of his neck.) Anywayz...I agree with you re the wiring/connectors. The fact that the problem didn't really crop up until the injectors were replaced...by some mechanic...makes me wanna say HMMMmmmmm.... P.
12-21-2012 | #46 | |||||
The range locks up and gives unexpected results. However, if you measured consistent "open" on a coil then ???? could be you theory bellow. In any case using a reasonable resistive value in series eliminates this. The early HPs were bad for this. Long story of how I know this. Quote:
I've been zapped hard a few times in my career, once by the HV section of a large screen CRT that just happened to be voltage regulated. It felt ME as a load and simply provide the necessary current to maintain it's V. I think I flew in the air a waz. Maybe 5ft. Quote:
Someone needs to go over and help get an answer. The suspense is sure there.
