#41 | |
![]() Join Date: Jul 2004
If I had someone to video me I could do that but Didn't really think about it when I was doing the work.
#42 | |
Maybe this will help. Last edited by XfireZ51; 03-08-2024 at 03:10 PM. |
#43 |
he has something like that but probably doesn't show how to check them with a DVM.
#44 |
Maybe this will help. Don't need to remove injectors to test resistances.
#45 | |
Your right he does not use a DVM. His Video shows the grounding a wire of Pack #3 on the ECM to verify secondares are engaged as well as direct power extension wire to the fuel pump to power up the fuel rails to check for leaks while the plenuim is off. He also how to reset the ECM without pulling the negative cable.
