Old 07-21-2011   #41
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Big Brakes Needed
Originally Posted by Blue Flame Restorations View Post
Phil, are you running a 17" wheel or 18"". If I run a 17" wheel, what is the largest diameter rotor I can run? 13" ???
So, can I run a C6 caliper with a 17" wheel. If so, what size rotor am I limited to running???
Brett,
I'm currently running 10"x18", 58mm offset Fikse Profil 10s on the front.
Before I was running the same 13" C6 brake setup with factory 17" A-molds which were at the limit clearence wise for those particular wheels.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-21-2011   #42
Thanks, Kevin. That helps tremendously.
What is the rotor size with this setup??
Brett,
The C5 rotors are slightly smaller @ 12.8" rather than the J55 rotors @ 13". They are thicker however.
Old 07-21-2011   #43
So what are the differences between the C5 and C6 base calipers?
Old 07-21-2011   #44
None. Identical. Z51 is different.
Old 07-21-2011   #45
C6 Z51 brake uses a 13.5" rotor. However, won't work on 17" wheels.
Old 07-21-2011   #46
Phil, Dom, thanks for the rotor sizes. I know it's a lot of questions. I feel like I should already know the answers but I keep telling myslef, "You have never had a ZR1 to drive daily".
I just want to make sure that I mod the car with something that I'll be happy with. I don't want to do it twice. I don't mind dropping $$$$, but I want to spend $$$ it wisley.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 07-21-2011   #47
Brett,
The C5 brakes are very good. They are not incrementally better than the J55s in comparison to having replaced 12" rotors w the C5s. However, if you are interested in using 17" wheels, the C5s are a value for the money.
Lots of rotors and pads to choose from also. Or get the C6 version which has a more stylized script on the caliper.
Old 07-21-2011   #48
At least I know what to shop or at Carlisle next month.
Thanks to all!!!!
Old 07-21-2011   #49
Jagdpanzer
Jagdpanzer's Avatar
Mounting interface is the same for both C5 Z06 and C6 base calipers.
C6 caliper hats are of beefier construction, have larger raised "CORVETTE" lettering, and have a cleaner overall look in my opinion.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-21-2011   #50
Thanks to all!!!!
If you find a worthwhile set of C6Z calipers, let me know.
