Old 07-30-2011   #41
Default Re: AM Rings?
Maybe I should just buy a Callaway
Old 07-31-2011   #42
Lee,
I checked the stock piston rings that came out of a 94 engine an the top and 2nd ring both measured 0.0681" (1.73 mm) and the oil ring 0.1378" (3.50 mm). Used an "old school" outside micrometer with a vernier scale.
Per the box these rings are 1.75, 1.75 and 3.5
Old 08-01-2011   #43
Message body
YOU SHOULD NOT HAVE ANY ISSUES WITH THE RINGS.
Thank You
Ed Law
Technical Sales
Total Seal, Inc.
22642 North 15th Ave.
Phoenix AZ 85027
PH (800) 874-2753 or (623) 587-7400
Fax (623) 587-7600
www.totalseal.com
On Jul 30, 2011, at 5:08 PM, Lee Gaffigan wrote:
Just wanted to check with you
Side clearance on top ring is .004
2nd ring is .003
Stock is .002 to .003
Backspace is .026 vs stock at .016
Any concern with backspace or top ring?
Old 08-01-2011   #44
Called total seal; .040 is when you start to have back clearance issues.
Old 08-01-2011   #45
Pete
Pete's Avatar
Lee,use the Total Seal rings and if they work we have another source for stock replacement rings,if not no biggie yank the motor and change to stock OE rings and done,it's some good R&D.
What's the part # on these Total Seal rings.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-01-2011   #46
Mine show as Custom order.....they advised these are the widest rings out there on the market right now......nothing closer. Easiest way to access is to have them check under my name. Calling Wiseco and a few piston companies to see what pistons would cost that use a more common size..like LS1/LS6 3.898
ZR-1 CORVETTE5.7L90-UP 3.89899.009 1.75 1.75 3.5 T1031 CR1031STDS/RSTD
Old 08-01-2011   #47
HAWAIIZR-1's Avatar
Lee,
You should be good to go and I know when I was contemplating the issue I had consulted with several builders. I had a little more clearance than what you are showing so I had concern with those rings and used OEM instead since I was able to get the last of loose sets from Jerry. Two of the builders knew of the ring issues from Total Seal and one used them. He said he could not notice any issues if there were. Even though I did not take a chance on them, I bought a back up set since I got it for a little over $120 as those rings I felt were better than no rings.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 08-01-2011   #48
I spoke to 2 other companies, they stated that they will not be an issue...
Wow this is a PITA
Old 08-01-2011   #49
Good info, note one poster is a mech eng/engine builder....
http://www.hotrodders.com/forum/lt-5...ml#post1451599
Old 08-02-2011   #50
Soooo, one builder thinks that the extra clearance is from wear (on the piston)?
Also, one builder thinks that it's okay but he is speaking in terms of a "hard wall" and a "hard piston" ( aka forged piston?, but ours are cast ) vs a cast iron bore and a cast piston.
btw, thanks for the link Lee.
