Old 02-03-2011   #41
Default Re: The phoenix rising
Originally Posted by sammy View Post
those look awsome .where can i order one ?
Ebay type in Billet oil cap LT4 it should pop up. Just ask for the mobil one insert.
Old 02-06-2011   #42
Old 02-07-2011   #43
Brillo1990
Hey Lee is there anyone that sells that LT5 plate on the front of that engine?
Brillo1990 is offline   Reply With Quote
Old 02-07-2011   #44
Carter I believe....I think its availble from the registry
Old 02-07-2011   #45
Yep Carter
Old 02-07-2011   #46
ScottZ95ZR1
ScottZ95ZR1's Avatar
Carter's UserID here is CARTER200 if you want to PM him.
ScottZ95ZR1 is offline   Reply With Quote
Old 02-07-2011   #47
carter200
carter200's Avatar
I make em' and you have a PM
Thanks all for passing on my name
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 02-08-2011   #48
Brillo1990
Thanks again guys, maybe sometime I can help out with some info for you too.
Old 02-09-2011   #49
OK guys, Pete called to report that motor started and ran today. I couldn't be there due to work requirements in San Francisco. Kudos to Pete and to Al for overcoming obstacles like 20.6" of snow and to match 3" collectors with 2.5" exhaust. Nothing like the FBI brethern to help out a fellow ZR-1er back in the cockpit. Gotta give out comps to Paul, Jeff, Lee, Jerry's Gaskets, and Marc Haibeck too. They all came to the aid of a brother. They're the best. Motor is up and running albeit needs some tweeking as in possible vacuum leak and better exhaust. With temps at 0 today, it'll be enough to drive the car back home and let it sit for a few weeks, an oil change, then I'll be back at it to get rid of the gremlins, replace the exhaust and possibly put Z06 wheels back on. Then to the dyno for tuning.
Old 02-09-2011   #50
Brillo1990
Good to hear it's up and running! We could sure use some thawing weather to get rid of some of this snow that's for sure.
