02-05-2011 | #41 |
Re: Some "Dynomite" Heads!
Thanks for the encouragement everyone
Quality of work is what I really strive for in doing this, takes forever but I think its worth the extra effort.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
02-14-2011 | #42 |
Almost done with the intake side of the heads. At this point I am mainly working the area around the valve boss and guide in an effort to provide a smooth channel for the air around these obstructions.
02-24-2011 | #43 |
Switching gears to the exhaust side, the stock valve guide bosses are huge and don't blend well into the overall port - much like the primary bosses on early style injector housings. The casting compensates for this somewhat by extra port width in this general area.
Here we have: left side boss with just a little bit of blending around the perimeter, right side boss with some rough cut size reduction. Some more rough cut reduction and blending A little closer shot of the same View from header side. Interestingly I have found that "as cast" one exhaust runner tends to be slightly larger than the other - near where they come together.
02-24-2011 | #44 |
Rob,very nice
Pete
02-24-2011 | #45 |
It's getting there. Maybe if I take my sweet *** time you can talk Cliff into doing some cams
02-24-2011 | #46 | |
I have a set done on the shelf no waiting,i would need his stock intake cores. Pete
02-24-2011 | #47 |
Nice Job Rob, nice to see the work of a true craftsman who cares about the final results of his hard labor
02-24-2011 | #48 |
Wow. Someone would have to be crazy to go through all the time and expense of head porting and leave at least 20 more horses on the table for 750.00. Sorry to get off topic Rob phenomenal work as always. A surgeon with a grinder.
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 |
02-24-2011 | #49 | |
If you want exhaust cams i would also need your stock ex.cam cores. Specs: Intake .236 .425 Exhaust .220 .425 What do you mean by what i do to them? of course i don't have the machinery to regrind cams i send them out. Pete
02-24-2011 | #50 |
The exhaust cams are worth about 5 hp.
With intakes alone you will see 15-20 add exhaust will 25. Pete
