#41 | |
#42 | |
![]() Join Date: May 2010
http://www.zr1specialist.com/HAT%20W...tion%20kit.htm I bought the JEG's cable kit that was 1 gauge cable with the terminals, lugs and heat shrink like this on: http://www.jegs.com/i/JEGS-Performan...10290/10002/-1 I also bought several different heavy duty grounding straps to several places in the front (block to frame) and rear area to make sure I had good ground. As noted on the first post of this I used an Odessey marine tray that fits perfect in the cavity as shown and seems made for the PC925MJT. I went with the MJT for the metal jacket and more rugged to handle more abuse. I can't make any other recommendations other than this one. It is 26 lbs versus the 21 pounds of the Braille B3121, but no issues for me at least with the Odessey. I think it you are going for just drag racing with lightest possible, then you have other choices with weight being the biggest concern. Mine being a street car I was looking for reliability with some weight loss, but able to still run LED hoodlights on cruise nights that Scott is making if I want to as well as short times with stereo while parked etc. Like Jep said, great battery, but if you want to go all out racing the lighter stuff, it will cost you and not sure how those handle regular driving and use. It sounds like you want the lightest battery possible and some of the folks on the C Forum with C5 or C6 mentioned some really light batteries and they do okay for them.
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#43 |
![]() Join Date: Nov 2011
I would do a ton of research before dropping a lithium ion battery in my car. They need to be charged very carefully, hear as computer controled. I doubt our systems are set up for that.
#44 |
![]() Join Date: Mar 2004
The white 441 car used Marc's battery relocation set-up. It wasn't cheap but the quality of the parts is what I paid for. And the battery lasted 4 years (yes 4 years) and the battery only needed a routine maintenance charge if the car was left unstarted for 4 or more weeks.
#45 | |
![]() Join Date: Jan 2009
Jep |
