#41 | |
![]() Join Date: Aug 2006
My first C4 was a 84 4+7 manual with Z51 suspension. With the top off, over the railroad, I could see the steering wheel move laterally by about half an inch! GM upgraded "K" member around 87 (I think). That reduced lateral shift by 1/8 to 1/4" - depends how bad the undulation is. My 91 Z, I had "Corvette Master" in Casselberry, FL, take an "X" member (sort of a c channel) for convertibles and stitch weld a plate effectively creating a box member. Front of coupe has a bolt hole already (I think). For the rear, Robbie had to drop a bolt into a plate and weld the plate to the bird cage. This worked real good but added some weight. |
#42 |
![]() Join Date: Sep 2005
That's what R-D cross brace is, stronger then a stock converitble cross brace.
http://www.r-dracing.com/CROSS-FRAME.htm I have this, it work VERY VERY well. It just hangs WAY to low to the ground. My car is lowered 1-1.5 and the cross brace can not be used for street driving. |
#43 | |
#44 | |
![]() Join Date: Jul 2007
Jason has been at Bloomington Gold this weekend, I am home afetr 3 days of the show and heat I needed a break. I have GP pricing, which is good, but it is tiered depending on amount of people, I am going to put a webpage together for the pricing and try to get a picture of the demo he had a chunk of frame.. But I think the discount will be good if we get enough interest. just a couple more days..
#45 |
#46 | |
![]() Join Date: May 2010
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#47 |
the OEM front location for the X brace and one bolt int he rear.. Jason will have all the instructions for mounting
#48 |
#49 |
![]() ![]() ![]() Join Date: May 2007
Im having a hard time determing how this mounts as well. Any better pics avail on a lift?
#50 |
![]() Join Date: Apr 2004
Jeff, thanks for getting the infromation and putting together a group buy. Any chance of getting a picture or a diagram of the pieces that come with the kit?
