04-22-2010 | #41 | |
Re: "New" Z on the way... 1991 #302
04-22-2010 | #42 |
Argh, I stripped the heads of 3 torx bolts on the passenger side cam cover. Grrr.
04-22-2010 | #43 |
I feel your pain, I did the same thing on mine, had to drill the heads off. Time for a set of SS bolts!
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
04-22-2010 | #44 |
Yep, that's the plan, I already have the SS bolts here, but 2 of the stripped heads are behind the AC/heater box... which means I think I may have to pull that out. Might go ahead and replace the AC evaporator, since I'm replacing the rest of the AC components too... lots of the dreaded "job creep" on a 188k mile car
04-22-2010 | #45 | |
good luck on the TORX Bolts.. I had 2 stripped on mine..
04-22-2010 | #46 | |
A friend showed me how a swift crack of a hammer on a sawed off allen wrench helps break the thread bond. Even in the hard to reach screws you can still sit a crowbar across the top and whack the crowbar.
04-25-2010 | #47 |
1994 ZR-1 Admiral blue/beige #67 |
04-25-2010 | #48 |
Got the passenger side cam cover off today, had 3 bolts that were stripped, lots of fun getting those out. Now, on to the driver's side cover.
04-25-2010 | #49 |
Driver side cover is off, no stripped bolts on that side
04-25-2010 | #50 |
