Old 02-28-2010   #41
Default Re: Noticed something interesting on my LT5...
I may be missing something here, but I don't see the significance of different casting dates for the upper & lower crankcases. They weren't "mated" parts until the machine work was done.
Old 02-28-2010   #42
1989ZR1#74
Until the last post the only date I saw was 3/07/90. Now that we have a 5/08/90 it makes the gap from LT5 to ZR-1 install much shorte and typical. I am just curious why the upper took so long to get mated? any idea why?
1989 ZR-1 #04 Pilot, Advertising/PR Campbell-Ewald S9YKH1
1989 ZR-1 #58 LT5 only
1989 ZR-1 #74 Unreleased Production / PR Dept 9PR110
NCRS #3,182 SACC #2,420
Member Corvette Museum
Corvette Forum: "ewjxn"
2009, 2010 Gathering Attendee
1989ZR1#74 is offline   Reply With Quote
Old 02-28-2010   #43
bdw18_123
It's actually not 5/08/90, it's 3/08/90. I guess in the picture it kind of looks like a "5", but it's actually a "3".
The oil pump also has a number printed on it (with ink) that reads: 03 0815 88. That may just be the part number, but could the first 4 numbers (03 08) refer to the date?
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 03-01-2010   #44
1989ZR1#74
So the whole LT5 appears to be assembled around 3/7/90. 2 things I now need to know. What were the stampings for ZR-1s from March? what do other May 90 ZR-1s have for casting dates??
Old 03-01-2010   #45
1989ZR1#74
Jerry, In you stock of LT5s are the two dates real close? Whats typical?
Old 03-03-2010   #46
bdw18_123
This thread seems to keep dying, so I have to bring it to life.
Discussion on this has been very interesting, still waiting on thoughts on Eric's questions above & any one with a '90 ZR-1 numbering in the 2000's (or any '90 Z really) somewhere to compare the casting date on their LT5 with their build date. 70-something day lag seems like a long time.
I want to figure this mystery out!
1993 Corvette Coupe
Old 03-03-2010   #47
phrogs
phrogs's Avatar
I have my 90 LT5 from #1908 Ill check that and post photos for you.
My ZR-1 is #845 or 854 I cant recall ill have to get that one on the lift and check it.
I also have a 91 LT5 that Ill post the pics of as well so we can see what I have.
Will have to wait until later
johnny
JOHNNY P
Currently own
Old 03-03-2010   #48
1989ZR1#74
Ok let me summarize my questions that will help decipher this mystery:
For now I am focusing on the Mercury Marine oil pan stamping and casting info. Any of these questions will move the ball forward:
What is a typical casting date for a May 1990 ZR-1 LT5?
What is a typical date separation on the upper and lower castings on any 1990 LT5?
What is a typical oil pan MM stamp number for a May 1990 casting date LT5?
What is a typical oil pan MM stamp number for a March 1990 Casting date LT5?
What is a typical oil pan MM stamp number for a #2000 to #2400 1990 ZR-1?
Anyone with this information on any 1990 ZR-1 may help so don't be shy post.
Old 03-05-2010   #49
bdw18_123
I notice BOB HDZ has 1990 ZR-1 #2293, his also would be a good one to check (in addition to phrogs' cars he said he would check and anyone else that has a '90 Z that can check) the LT5 cast date/car build date since that is the closest one to mine so far, tom tom's being the 2nd closest.
1993 Corvette Coupe
Old 03-08-2010   #50
1989ZR1#74
I found a note in the 9/1990 Corvette Fever that supports the non warrantee exchange that we discussed early in the thread. This supports the conclusion that the LT5 in #2299 was not a repaired LT5.
