Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Prototypes (pre-production)
Old 01-25-2010   #41
1989ZR1#74
Default Re: 1989 ZR-1 Pilot #004 Thread
Tyler just emailed that the he thinks #004 went to the trade school in 1990.
1989ZR1#74 is offline   Reply With Quote
Old 01-25-2010   #42
1989ZR1#74
Found a reference to the ZR-1 at Sheridan Votech Center from the February 20, 1992 edition of the Miami Herald:
"The Sheridan Vocational-Technical Center in Hollywood held its third annual open house Feb. 10 and 11 for its automotive program. The open house was in recognition of National Vocational Education week, Feb. 10 to 15. General Motors and Ford provided demonstrations on these automotive topics during the open house: super and turbo charging, 375 horsepower ZR-1 Corvette, computerized shifted transmission, Freon-recycling, distributorless ignition system, air-bag deployment and certification legislation. "
Old 01-25-2010   #43
Corvettes White
Originally Posted by 1989ZR1#74 View Post
But I now know why the Odometer is under reporting the miles...
Not sure maybe the 8000RPM dash wasn't ready yet, but I doubt that.
Eric
Question for you. What is the squareish circle inside the circle in the middle of the photograph? just above the digits? It looks like part of the cluster, but never seen it before on an 8000 rpm dash nor on a 6000 dash. When I look in the owners handbook is shows in some of the small graphics and not in others. thanks, George
Corvettes White is offline   Reply With Quote
Old 01-25-2010   #44
Jeffvette
Originally Posted by Corvettes White View Post
Question for you. What is the squareish circle inside the circle in the middle of the photograph? just above the digits? It looks like part of the cluster, but never seen it before. thanks, George
Overdrive light for a 4+3 manual 84-88 car, since that is what the cluster came out of.
Old 01-25-2010   #45
Is there an RPO code sheet on the bottom of the center console door?
Old 01-25-2010   #46
1989ZR1#74
The SPI is there and intact. Will post a picture of it tomorrow.
Old 01-25-2010   #47
Corvettes White
Thanks Jeff.
Old 01-25-2010   #48
Often on C4s you can faintly see the assembly date written on the underside of the hood, its towards the front of the hood on the D/S. Usually written in a white pen, almost looks like wax.
Old 01-25-2010   #49
Mine said June 6th I believe
Old 01-26-2010   #50
Tyler Townsley
Been involved in a little car show for the last week or so and misssed the tread. Someone has swaped out the dash cluster with a stock unit, it had a ZR-1 unit on it when I saw it and 270 miles so it is over reporting the actual mileage. I suspect it was done at the heritage center and maybe they know where the original unit is. The ERR code can only be fixed by sending it off. I had to have mine fixed as there are some solder spots that will go bad after a time. Aparently the ckt board welder had it problems.
The early DIS module had problems so you might want to check it. Best way is to pull all the plugs connect them to the wires and lay them on the plenum. Crank the car and watch the spark acrosss the pulgs. There should be a rythem to the flashes, if there is not then the dis module may be bad.
They also displayed the car at some of the Miami International car shows. It was at one of those events that they were offered $250 k for the car.
Tyler
