Old 3 Weeks Ago   #41
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Engine noise- stuck lifter?
My heads have those grinding marks too. They are from the finishing work done at the factory to remove casting flashing during production. From what I can see nothing to worry about.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 2 Weeks Ago   #42
bob@tradeshowconsulting.c
Originally Posted by Tim555 View Post
When changing the oil I noticed this part appears to be loose. It looks like the timing chain tensioner. See the video linked below. It also looks like the chain is rubbing on something. There are rub marks visible. Is this normal?
https://youtube.com/shorts/lVDWThbNe...VWj6Dx96yDdgfn
Please confirm that this loose chain guide in the video is not supposed to be loose ..? and how did you tighten it ?... because the wear strip is a separate piece and ......was it damaged? what caused the marks on the chain ? etc...
And ultimately was this the cause of your noise? or just additional issue ?
Hoping you find answers and get it resolved
Thanks
Bob
bob@tradeshowconsulting.c is offline   Reply With Quote
Old 2 Weeks Ago   #43
Tim555
Thanks
Bob
It wasn?t really that loose when I took the cam cover off. I did not figure out what the cause of the noise is. I?m in the process of putting the cam covers back on. The passenger side is very difficult to get back on!
Tim555 is offline   Reply With Quote
Old 2 Weeks Ago   #44
did you re-secure / Tighten the chain guide ? is it bolted in or screwed in ?
