02-21-2014 | #41 |
Re: Fun winter project
slowly making progess..
I have a better power supply Tested everthing in the car, almost smoked the EQ I have since the Level control I have was marked backwards.. so al max Attenuation it was a short on the output of the EQ.. I also took it apart to find it is a Linear Pot, not Log.. I ordered some Log and Linear Pots, I am debating on doing a homebrew Vol/Bal controls and skipping the EQ, but then the Tuner will always be flat.. another option I thought of was getting a bluetooth transmitter ans ending the tuner signal to the bluetooth input of the Nexus, then I could eliminate the Level control.. More I think about it I think I will keep on my same path with at least a level control ( might do the balance as well) then possibly run the EQ (hidden in the glovebox if it fits) the 2 knobs will go on the bezel to the right of the power key, I like the aluminum knob I got with the level control so I need to order another or find some on eBay. I did find that it is LOUD, I had to turn the Amp Gains way down, which is a good thing I suppose
02-21-2014 | #42 |
Ok, what year did the glovebox go away?
My 95 doesn't have one!!! |
02-21-2014 | #43 |
93 was the last year.. In 94 it became the Airbag
02-21-2014 | #44 | |
Good job on the mount - cutouts for all the ports? What's USB version - 2.0? 3.0?. Any rubber affixed for vibration absorption?
02-21-2014 | #45 |
USB 2.0
Speakers are CDT, Amps are Arc Audio
02-21-2014 | #46 |
True... True.. and the first year of those handy door pockets
03-25-2014 | #47 |
quick picture
03-25-2014 | #48 |
-=Jeff=- is it still fixed another concern I had was over heating the battery and a fire potential. I remember that photo of the nav unit that was plugged in and the sun helped to overheat it causing a fire as the battery exploded
03-25-2014 | #49 |
Yes still fixed. Not as concerned since it will be in the cab and not direct sunlight as it would be on the dash. I am also looking to see if someone comes up with a power supply solution to replace the battery..
03-26-2014 | #50 |
I would think you could remove the battery and run straight from the car battery. What does your plug in charger put out DC volt wise to the tablet?
Scott Vett owner since 1979._It's about the car and the people Last edited by scottfab; 03-26-2014 at 08:52 AM. |
