11-29-2017 | #41 |
Re: No heat from heater 1990 ZR1
The 15-71937 is the ACD for the 89018368 that I mentioned. If you decide to buy and try confirm it's returnable if it doesn't work. A friend at a dealer has mentioned problems for some of these newer actuators.
I'd suggest a conversation with a local ACD jobber or a dealer before the buy. |
11-29-2017 | #42 | |
Thanks.
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
11-29-2017 | #43 | |
"I don't think changing the year programmer is in your interest. The LT-5s use a different signaling method to communicate with the ECU, and they changed over time, so whatever you do, stick with the correct part for your year car." So the way I understand it the actuator regardless of position on the top or bottom of the heater core box is controlled by the AC programmer. I'd have to switch to a 1994 programmer which might not communicate with my 1990 ECU. Unless I am misunderstanding . So my best route appears to be the stay with the 1990 components, once I find an actuator I am sure works. Is my logic sound? Thanks.
11-29-2017 | #44 |
How much is the part? if not too much might be worth getting
11-29-2017 | #45 | |
11-29-2017 | #46 | |
Talk to a local dealer also maybe - buy from whichever understands the issues. Works you keep, doesn't you return - maybe offer to accept merchandise credit if you need to return! Try to negotiate a price to maybe something $80 or less! |
11-29-2017 | #47 |
swapping the programmer?
GM SPO has different part # for MY and also engine RPO - 92-93 - LT1 92-93 - LT5 94-95 - LT1 94-95 - LT5 Seems that when they started to supply REMAN they would have consolidated the part #'s. My SPO information was current in year 2000 Consider also that with R134 conversion in '94 there was likely different values expected from components. I've certainly no 1st hand experience but I ain't wanting to try |
11-29-2017 | #48 | |
Also spoke with my local chevy dealer. GM16124952 is NLA, checked nationwide database NLA. I gave them ACD 15-71937 which they said crosses to GM89018368 (as you said) which is readily available. $138.00 non-returnable. ACD 15-71937 is available from United for $95.00 and is non returnable. I will probabily end up buying the ACD one if the two I have do not work. I don't mind spending the $100 if I can get this working, this is the worst repair I have had to make on a corvette, I am just getting frustrated. I think swapping the 1990 programmer with a 1994 at this point is a not going to happen. Sorry for the drama.
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) Last edited by jrd1990zr1; 11-29-2017 at 03:51 PM. |
11-29-2017 | #49 |
Yeah I understand. I need to read through the thread again to see what you have already done
11-29-2017 | #50 | |
Ultimately I believe the best buy is the "local" and NOT an Internet buy. |
