04-01-2013 | #41 |
Re: dyno numbers / upgrades done
I had 444rwhp last year before Wazoo installed my 63mm TB
(Done by Marc) recently. I might have another 5rwhp? I need to do another dyno!!!! David |
04-01-2013 | #42 |
Yeah, I talked to Pete about the bigger TB. I'm very interested to know if you pick up any power.
04-03-2013 | #43 |
I just got my car back from Marc after he did his Haibeck 510 package. Achieving 510 CHP would require about 433 RWHP by his 15% loss calculation. Mine actually Dyno'd at 413 RWHP/367 RWTQ. I did not install a Fidanza Flywheel and instead kept my old Dual Mass (because I often shift into neutral at stops and don't like the trans rattle), which cost 13 RWHP according to Marc. I also had him install ceramic cats which both helps the envrionment and softens the Corsa exhaust sound considerably. He said cats typically cost about 7-8 RWHP. So 413+13+7=433, so the porting, headers and cam timing seem right on. I had Marc put his 510 label on the engine since that is what it is if you just install a Fidanza and replace the cats with straight filler pipes. Which at some point I might just do.
Not going to beat Pete but a pleasant car to drive with a substantial boost over stock. As I have said before, a Gentleman's FBI car. Permagrin. Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 04-03-2013 at 05:00 PM. |
04-03-2013 | #44 |
Nice numbers, clean engine. What gears do you have?
1966 Mustang GT tribute 1988 Callaway Twin Turbo Aerobody (FOR SALE pm me for more info) 1991 Callaway CR1 SuperNatural 475 Aerobody 1992 Callaway SuperNatural 435 Aerobody (sold) For Sale: |
04-03-2013 | #45 |
Bob Your car is powerful, yet quiet like a stocker!!! Did you get Marc's 63mm throttle body? Great dyno numbers!!! Can't wait to see it @ BG David |
04-03-2013 | #46 |
To answer both questions at once: I have 4.10 gears which I think from a seat of the pants standpoint somewhat make up for the lack of the Fidanza flywheel even though the effect doesn't show up in Dyno numbers. And yes I did get the 63 mm TB. That is part of Marc's package. I have only driven it a little bit (it is still cold here) but I definitely look forward to playing with it a bit more soon. --Bob
04-04-2013 | #47 | |
Will you be at BG?
04-04-2013 | #48 |
Yes I will be at BG. Coming in Wednesday afternoon is the plan. -- Bob
10-10-2013 | #49 |
1990 LPE 475 Package
Best of my Knowledge: Stock Cubes, 12 to 1 Cosworth Pistons, Oliver Rods 3" exhaust w DynoMax UltraFlow+Z06 NPP Pete's re-ported intake & I/H, Stock Cams 1998 Lingenfelter Cylinder Head Porting Stock Dual Mass Flywheel, Jeal Headers Cold Air Intake from License plate cover with Dirty K&N filter connected 4.09 gears, Sans Secondaries Right off a 400 mile solid drive onto the Dynojet Dyno Rack 400 RWHP....370 RW Torque in Ohio, It dynoed better in Chicago Thinking of More Aggressive Cylinder Head Porting & Pete's Cams The car is a blast to drive on the street.....Took SS Camaro with ease Last edited by alnukem; 10-10-2013 at 02:01 AM. |
