#481 |
![]() Join Date: Mar 2014
Pic #9...these plastic fasteners are also used in the bottom spoiler area....one on the LS is the exact replacement....RS is the stock part...
Pic #10...the Hillman Ford parts are the same as what is on the ZR-1.... Pic #11....2 to a pack....20191007_164047.jpg20191007_164128.jpeg20191007_164147.jpeg Sent from my SM-G965U using ZR-1 Net Registry mobile app
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member |
#482 |
Pic #12....also purchased some extra bolts attaching the lower radiator support in place...as they are a different style of bolt....the 94 is on the far right....the other 4 are "just in case"....
Pic #13.....topside....in very good shape....all cleaned and ready to go....20191007_162521.jpg20191007_162525.jpg Sent from my SM-G965U using ZR-1 Net Registry mobile app
#483 |
![]() Join Date: May 2010
Hey Tom, Just a note to say thanks for sharing. You probably have no idea how much your posts will help someone one day. Some good details and lessons learned and good how to. Even the “lurkers” appreciate it I’m sure. When people are appreciated I know it motivates them to continue the act. Take care and keep up the good work.
Aloha, Craig 1995 #228 Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#484 |
![]() Join Date: Aug 2012
Tom,
Wazoo maintenance day this Saturday. Hope you can make it.
#485 | |
![]() Sent from my SM-G965U using ZR-1 Net Registry mobile app
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 10-08-2019 at 12:28 PM. |
#486 | |
Looks like everything is well on your end, some great pics that you have posted from your new location. Take care yourself....chat soon!!! ![]()
#487 | |
![]() Join Date: Nov 2016
- '90 ZR-1 |
#488 |
Thanks and appreciated.....
#489 | |
Hey Tom! You’re very welcome. It is understood the time and effort it takes to do write ups and take photos. Yes, you’re right about Dynomite Cliff and I’ve shared the same with him over the years. As you know a few years of hiatus from the Z, but never forgotten are the friends on here. Take care and Aloha!! Craig Sent from my iPhone using ZR-1 Net Registry
#490 |
Having researched through the forum on AC condensers....I ended up purchasing a Spectra Premium 7-4557 condenser for my 94 ZR-1
There was mention in the older threads that this unit may not have provisions to install the oil cooler, this unit does with one exception and that is you need to elongate the holes on the RS (passenger side) of the oil cooler for it to fit and possibly use a larger washer under the 7mm attaching screw....no biggie... As you may be able to determine in the pics, the body of the new condenser is slightly smaller than the original unit.....even the overall dimensions from side to side are slightly less....but the top to bottom measurements and the hose connections measurements are the same....the only difference in modifications that I can determine at this point is that the RS upper and lower front part of the radiator rubber cushions would have to be slightly modified to make sure that the new condenser is secured... Having said that I am taking my original condenser to get pressure tested and make my decision when I get back the results....we shall see... Here are some pics.... Pic #1....numbers on the original condenser... Pic #2...the original... Pic #3...original with oil cooler... Pic #4...Spectra part #... 20191014_105205.jpg20191014_104457.jpg20191014_104544.jpg20191014_104952.jpg Sent from my SM-G965U using ZR-1 Net Registry mobile app
