12-18-2011 | #461 |
Re: LT5 Assembly Project
Just something to ponder and engineers please verify my math....diameter of of the cam base circle is about 28.77mm and if I remember my high school math that makes the circumference 90mm....which means the one degree on the camshaft is 1/4mm?
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 12-18-2011 at 11:03 PM. |
12-19-2011 | #462 |
360 degrees in a 90mm Circle would mean 1 degree=.25MM correct? I guess the point I am making is that it does not take much to move the cam a few degrees in reference to the crank.....
I am doing a novice write up on cam timinig....
12-19-2011 | #463 |
This camdegree setup is genius; uses the plug hole as a stand and two dial gauges split off...
12-19-2011 | #464 | |
P.
12-19-2011 | #465 |
right paul, Hard to believe how small the adjustments are......D/s is done ended up at 113 and 108 locked down and loctited. With Jerrys torque bolts process, is very easy and does not seem like the cams move.....on PS I will mark the cams to see....
12-27-2011 | #466 |
P/s is done 112.5 Intake and 108.5 Exhaust....
D/S is 113 Intake and 108 Exhaust Home stretch....... Paint plenum Seal down fron cover Oil Pan Oil filter housing Cam Covers
12-27-2011 | #467 |
Every project needs a name, right?
12-27-2011 | #468 |
Lee,
"LGAFF's Stillwater Revival" also has a nice ring to it. 470 posts so far on this thread. Thanks for sharing your LT5 jouney with us. You're in sight of the checkerd flag. Good luck on the final laps.
Phil Wasinger 1994 Torch Red ZR-1 WAZOO Member George Braml Intake Last edited by Jagdpanzer; 12-27-2011 at 07:27 PM. |
12-27-2011 | #469 |
Its either that or the "Never Ending Project"
12-31-2011 | #470 |
Oh so close...
Down the rabbit hole:
