Old 09-07-2019   #451
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
More progress today before taking some time off....fans are out. .and now so is the lower radiator support...
Have to think out my cleaning strategy when we return...next week will give me time to do just that!!!
Broke one of the tabs for the wire loom in pic #3...still useable if unavailable....... but I imagine that they may still be available from the dealer..20190907_133511.jpg20190907_133528.jpg20190907_133630.jpg
Sent from my SM-G965U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-07-2019   #452
Roadster
Roadster's Avatar
Lower radiator shroud is out....20190907_135353.jpg20190907_153020.jpg20190907_153205.jpg20190907_153200.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-07-2019   #453
Roadster
Roadster's Avatar
Just did a quick wash on the lower shrould....pic #1...the part #....
Pic #2....one of 5 10mm bolts and nut washers that attach the front of the lower shroud to the top of the center air dam.....passenger side in pic #2 & pic #3 does not come out when loosen....it stays in the shrould....as the metal bar shown in pic #3 overlaps that bolt....looks like metal bar in pic #4 took a beating in its earlier days from the front air dam taking some rough bumps....20190907_161508.jpg20190907_161525.jpg20190907_161544.jpg1567887867017.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-17-2019   #454
Roadster
Roadster's Avatar
Fans went from looking like this in pic #1 to like this in pic #2....pic #3 shows one of the radiator rubber supports...it appears that this system was removed before....as the front of both rubber supports where the condenser sits....was reformed during installation...as the time wasn't taken to make sure the parts sat correctly in the support....pic #4 shows a first cleaning of the supports...plus you can see how the rubber was deformed...tried in pic #5 to reform the support....but then thought it might work out better as shown in pic #5...#6...& #7.....just taped to the condenser itself....we shall see...will probably go with the poly version...sine the OEM rubber versions are not available...
Also getting the AC Compressor manifold hose assembly repaired...should be completed in a few days...interesting on how they are doing the repair....[emoji16][emoji16]20190914_114331.jpeg20190914_225355.jpg20190917_131757.jpeg20190917_132558.jpeg20190917_132709.jpeg20190917_142713.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-17-2019   #455
Roadster
Roadster's Avatar
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-17-2019   #456
Roadster
Roadster's Avatar
Accumulator holder redone with new accumulator installed....pics #3 & #4 before pics....getting ready for paint...[emoji16]20190917_182955.jpg20190917_183007.jpg20190917_152453.jpg20190917_152441.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-17-2019   #457
Mystic ZR-1
Mystic ZR-1's Avatar
That accumulator will easily polish up like chrome...
Old 09-18-2019   #458
Roadster
Roadster's Avatar
Hello Doug, I don't have any experience with doing that...sounds interesting...
Also ordered a new fan motor, as one of my fans is making a worn bearing noise when turning by hand. And taking your advice for a new radiator...will order one soon....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-19-2019   #459
Mystic ZR-1
Just pick up a couple buffs for your electric drill and a stick or 2 of compound
at your local hardware store or Home Depot. Not too much $ and easy to do.
(before you put it in the car...)
Recommend a DeWitts 2 row radiator, 32-1139090M, shop around for best price with free shipping...
Old 09-19-2019   #460
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Tom,
I have the proper and new De Witts Radiator in my stash for your car if you need/want it.
90M new in box.
current price 569.00+ ship
less discount for you taking pictures of Ruby at Carlisle for me
Hows $400.00 and a visit?
Let me know.
Marty
