Old 07-07-2018   #421
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
I know u are trying to avoid removing the plenum, but have u checked the ac clutch harness connector? They are notorious for cracking and disintegrating.
FWIR......when I did the plenum pull last summer......all appeared to be in good shape.....of course if this bearing replacement doesn't correct the problem....then I will have to look elsewhere.....I do have a kit to rebuild the compressor if necessary and would then be checking the clutch harness connector as you suggest......but right now I am leaning to the clutch bearing....you could really feel the difference between the two......so hopefully this is the answer......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-07-2018   #422
Roadster
Roadster's Avatar
Originally Posted by mgbrv8 View Post
If you go back through the heart of the beast articles I did an extensive rebuild on the AC system for our cars and how to rebuild the AC compressor
Dave.....I did read that article before.....which is excellent and that is what prompted me to purchase the rebuild kit mentioned in the above post.....but I'm hoping that the clutch bearing replacement will be the answer.....I will know tomorrow for sure...….
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-08-2018   #423
mgbrv8
If you need any help please feel free to send me a message and we can set up a call I’ll be happy to what I can.
Dave
Old 07-08-2018   #424
Roadster
Roadster's Avatar
Dave
Thanks Dave.....it is appreciated..... If I run into a problem....I will take you up on the offer.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-08-2018   #425
Roadster
Roadster's Avatar
Well Dave....looks like I'll take you up on that offer.....will send you a PM....
Partial success today.....in that everything went back together......AC clutch seems to rotate all of the time now.....and although the air in the cabin was cool when I first started the engine.....it was just warm....freon gauge shows that I might be overfilled......and there is slight noise being heard now.....low pressure tube is not cold to the touch.....
Sent from my SM-G935P using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-20-2019   #426
Roadster
Roadster's Avatar
Well it's been awhile since I've posted up....I haven't run or evan started the 94 since last June....ever since I did a number on the AC Compressor...
Have a new one ready to install and noticed when I slightly lifted the plenum....the gaskets ripped on both sides....kind of disappointed with that as they only had a few thousand miles on them..
Ended up pulling the plenum completely....will order new gaskets or reuse my originals....[emoji849][emoji16]20190520_164238.jpg20190520_164254.jpg20190520_174937.jpg20190520_174941.jpg
Sent from my SM-G965U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-20-2019   #427
G8nightman
G8nightman's Avatar
Defiantly get new ones
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is online now   Reply With Quote
Old 08-20-2019   #428
Roadster
Roadster's Avatar
Started working on the 94 again and made some progress.....the radiator should is ready to come out....those 6 screws were a PIA as many have mentioned....did not have to remove anything on the passenger side....but removed items on the driver's side to gain access to those 3 screws...also a chance to clean the leftside well with parts removed...
Done for the day....will remove the shroud tomorrow....just have to remove the small hose connected to the top of the radiator in order to lift the shroud out....determined to get the AC operating once again and to start the engine once again since June of 18....
Still need to change out the accumulator....check the condenser and the radiator and I guess the oil cooler...
Making progress....[emoji16][emoji16]
In the pics below...
Horn cleaned....
I imagine the next pics are a vacuum tank.....cleaned....
20190820_180709.jpg20190820_180715.jpg20190820_181420.jpg20190820_181431.jpg20190820_174501.jpeg20190820_174907.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-20-2019   #429
Roadster
Roadster's Avatar
More parts cleaned....
The AIR pump....also some parts #'s shown for future reference....20190820_182714.jpg20190820_182727.jpg20190820_183531.jpeg20190820_183703.jpg20190820_183651.jpg20190820_183731.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-20-2019   #430
Roadster
Roadster's Avatar
Inside the left front well....
Before cleaning and first preliminary cleaning....should come up good after I'm finished....
All 6 side screws out....
Some of the wrenches needed to do the job....would have been a breeze for the top screws on both sides with a 7mm ratchet wrench....but couldn't find one locally....also 9/32" socket or wrench will also work....
Was too hot to go out to the 74....so the portable garage AC unit did good in the above 90 degree temps today...garage was in the low 80's and comfortable....[emoji16][emoji16]20190820_184139.jpg20190820_201758.jpg20190820_193633.jpg20190820_193623.jpeg20190820_184048.jpeg20190820_184101.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
