Old 10-10-2011   #411
Default Re: LT5 Assembly Project
Big setback, did and leakdown test and none of the valves hold pressure....all 8 cylinders failed, bigtime.....more to come.
Old 10-11-2011   #412
tccrab
tccrab's Avatar
Didn't one of the FBI members run into similar issue about a year or so ago when the valves were a smidge too long after a valve job?
Gotta go do a search.....
BRB
Here it is:
http://www.zr1.net/forum/showpost.ph...0&postcount=25
Possibility?
TomC
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 10-11-2011   #413
Engine was tested with cams......
Old 10-12-2011   #414
tccrab
tccrab's Avatar
Lee:
Didn't read through enough to see if you used new rings, but if you did then they're probably just not seated into the cylinder walls yet.
Perform standard engine break-in routine and then retest.
HTH!!!
TomC
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 10-12-2011   #415
Bob G
Lee do you wan't to stop buy and check it out for you?
MR 134+
Bob G is offline   Reply With Quote
Old 10-12-2011   #416
Bob I am about 100% sure its a bad valve job......I am home today if you want to stop by......I pulled the D/S head and no marks on pistons, etc so appears nothing that I did....
Will be back home at 4:30 or so
Old 10-12-2011   #417
MR 134+
Bob,
I didn't believe it when you said it, but you are even more insufferable at 134+mph than you were at 128!!!
Old 10-13-2011   #418
Bob G
Talking Re: LT5 Assembly Project
Don't You Just Love It
Old 10-13-2011   #419
tccrab
tccrab's Avatar
Lee:
If you didn't do the valve job, then the million dollar question is who did the valve job and how on earth did they fubar it so bad?
One or two I could understand, but to goof up at least 1 valve on each cylinder seems highly unlikely.
TomC
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 10-13-2011   #420
Very experienced shop, not sure what the story is at this time, will withhold any judgements until the verdict is in....lets not forget that these heads had a prior valve job and ate a screw.....so there could be alot of issues. I assembled the heads, etc....so maybe its something I did...
Maybe there is not even a problem......
But here is the main reason I am concerned.....this is at 45PSI
Exhaust valves:
