#391 | |
![]() Join Date: May 2010
Thanks for the feedback and reply. I have been on the move since I acquired 95 #228 so I have not had a chance to service and check cooling system, but got the Fluidyne for trade of couple wheels so I might as well install it. I bought the silicone hoses and clamps from you last year and I have a couple OEM thermostats laying around. The challenge is finding the green coolant for our cars around here. I think a fellow Z owner damaged his LT5 from Toyota red coolant. I remember you sent me the diagram photo of where to drill the holes should I decide to do so. Thanks again for the sound advice as usual. Well, gotta go and install the RaceDeck flooring I bought from Mom! Craig
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#392 | |
![]() Join Date: Sep 2008
Tom, I am not certain that anything is really wrong. On 50 degree mornings, my car runs in the 170's from home almost to the shore, over 50 miles. Upper 70's when stopped; lower, almost 169 when doing 75. No holes drilled, and a 180 stat. The past few days have been in the teens and 20's. Flying along in those temps could keep you down where you experienced. Don't go crazy yet. Wait and see how it is when it is at least 50-60 outside. We have been working on a 71 LT-1. Left it idling for half an hour; 130 degrees. Changed the stat from 160- 180 as we had no idea how old the one in there was. It has come up to 150, but no higher, all with a verified gauge. Some cooling systems simply are very efficient. Merry Christmas and Happy New Year to you and your wife! Stop down sometime!!! Marty |
#393 | |||
![]() Join Date: Mar 2014
Having not driven the ZR-1 on the highway in extreme weather like yesterday during previous winters.....I don't recall the temps being that low on the highway.....I can't say for sure if or what, if anything was done to the thermostat.....but conditions were just like you described....I was just being concerned....lol.....you think after all the years of driving a big truck....I would remember how drivers would cover the radiator grilles and have only a small opening to limit the air flow to the radiator to keep the temps up during the winter months....I need to go back to Cooling 101....lol and take a refresher course..... ![]() Quote:
I always let the LT5 "warm-up" before driving down the road.....and noticed that in the 19* weather it did take longer than usual before getting up to operating temps..... There was not anything unusual driving.....but since it is the LT5.....just more concerned.....lol as I want it to run perfect all of the time.... ![]() Feeling better that it seems this is normal operation in extreme temps.... Happy New Year to you also...... ![]() Quote:
With everything being said.....I would imagine that my cooling system is operating at peak efficiency.....based on all of the replies posted..... ![]()
#394 | |
And the fact that your runs similar to mine as you described and without a drilled thermostat...... And yes quite cold in our area and for most of this week..... Interesting about the LT-1......I guess we can come to the conclusion that extreme cold temps plays havoc on the cooling temps.... And thanks.....Merry Christmas & Happy New Year to you and your family also...... I will stop down soon.....will give you a call and we'll set up a time.... ![]()
#395 |
Sorry Marty, but there’s no way GM would allow the car to run at anything below the point where the ECM is not LEARNING and modifying the fueling for BLMs. No matter what the conditions. That’s part of what cold weather testing is all about.
The coolant needs to be at >80C for that. Anything below that for other than warmup is not what the calibration is looking for. That doesn’t mean it won’t run but it defeats the whole point of Closed Loop operation. |
#396 | |
The car feels MUCH stronger at 170 degrees. I am no engineer, but it has behaved that way for 20 years, and I am good with it. I won't tell GM, so let's keep it a secret. ![]() Marty |
#397 |
Most of that were “tricks” to fool the ECM. The issue involves emissions, mpg et al. Not a question of performance which really deals w Open Loop. I’m just stating fact on how the calibration works not making a judgement call.
#398 |
I am with Marty and I have LT5 secrets I explore in public for sanity checks and I welcome ALL Comments
![]() I have been called an Engineer....sometimes...... ![]() Sent from my iPhone using ZR-1 Net Registry
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-30-2017 at 11:49 PM. |
#399 | |
I got a few secrets of my own. |
#400 |
Minor update today......42* out.......took the 94 out for a countryside run.....some nice back roads.....no actual highway driving today.....felt real good.....temps were operating as they normally do......everything went fine...
so as many have mentioned above.....apparently there is nothing wrong with my cooling system...and the results I experienced that day were due to the extreme frigid temps and the highway driving speeds on the highway.......contributing to the cooling temps I saw...... ![]()
