Old 10-17-2009   #31
Default Re: 1 Cyl miss, out of ideas, might sell cheap..LOL
Originally Posted by SharkPilot View Post
Tyler,
How does a valve spring get broken when the cylinder fires with the valve part way open? I'm not doubting you at all it just seems puzzling to me.
Does it send some sort of shock up the valve and stress the spring?
Thanks,
SharkPilot
Wouldn't it make sense that the explosion could slam the valve back into it's seat sending a shock wave thru stem & to the spring? The impact would have a lot of energy to transmit somewhere? I could see the hydraulic lifter acting like an anvil with the sudden attempt to squeeze all the oil out of it, from the missfire, very quickly and the hole is too small to handle the oil flow?
If you don't have some one close by to lend you a known good ECM. I have a spare that will work for a 90 with a stock 90 EPROM in it. It's not a 90 ECM by the numbers, but one of the later ones that will work on a 90. Hit me up if you think you want to go in that direction.
Did you run down the flow chart in the FSM for a DTC 62? That could tell the state of your ECM also.
One other thought. I'm embarrassed to mention this. What happens when one of the 90's "quad drivers" malfunction? Could that cause just one injector to go dead?
Old 10-17-2009   #32
Spanky1965
flow chart in the FSM for a DTC 62? ???
Quad drivers??
Spanky1965 is offline   Reply With Quote
Old 10-17-2009   #33
You mentioned aftermarket coils which have known to be a problem. Is it possible to swap out the approriate coil with a Delco unit? Great ideas guys keep em coming also can anybody close by Hook a brother up to test the ECM problem with a swap to rule that out as well?
Old 10-17-2009   #34
Spanky1965
well had the problem before I changed the coils, I 100% have spark, and yes please keep the ideas coming
Old 10-17-2009   #35
Tyler Townsley
Tyler,
Thanks,
SharkPilot
Your guess is as good as mine. I just know what did it.
Old 10-17-2009   #36
Tyler Townsley
OK we need some info from you. What did you see when you tried the things mentioned especially what the plugs look like. Take them out put them in order by cyl take a picture and post the picture. Without feedback on the tests we are blind.
Tyler
Old 10-18-2009   #37
Quad drivers??
Sorry, my senility is showing. I meant to write DTC 64 the right o2 lean condition. If you run thru the flow chart steps you will know with a good degree of certainty if the ECM has crapped out on you. At least a definitive answer would be nice to have.
Quad Driver = Secondary Injector Relay = official GM name for the part. These can't be the issue, sorry I always forget which injectors they control.
My apologies, sometimes my fingers are in gear and my brain isn't in the loop!
Old 10-18-2009   #38
gbrtng
gbrtng's Avatar
"Quad Driver = Secondary Injector Relay = official GM name for the part."
Not so much - the quad driver is an output transistor in the ECM (probably CMOS) that provides current to 4 injectors. There are no relays in the system.
Old 10-21-2009   #39
Spanky1965
Ok guys, after $2000 of parts and Jeffvette even gave up helping me or returning my calls, I took it to the local dealer, turns out the PCM conector had poor terminal tension, they removed the bad ones and soldired and pluged it back in
Car now 100% perfect, thanks for all the help,
Just an FYI to all, watch out for some of the "experts" on here, they like to have you change parts, its not there money.
Old 10-21-2009   #40
Spanky1965
just to be clear on my last post I am very thankfull for everyone that offered ideas, I am taking about the guys that claim to be the experts
