08-16-2009 | #31 |
Re: Crankshaft rear seal didn't fix the oil leak
Grape juice .
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
08-16-2009 | #32 |
Okay, I don't know of a dye, maybe water based food coloring?
This thought just hit me. The trans fluid is new? The motor oil will get contaminated with blow by & turn dark, almost black. Why not wait till that happens then compare colors? It shouldn't take all that long. Or not. I know, I know, I'll go........
08-16-2009 | #33 |
There is a dye for engine oil, available at auto parts stores. Ryan knows that, he's just being a wise azz because he know his winter is just around the corner.
PS Tom, you let your oil get black before changing? Naughty naughty, bad Tom! There is another way. Drain all the oil out of either the engine or tranny, drive it around a bit. Then if it still leaks you know where it came from.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 08-16-2009 at 01:23 PM. |
09-02-2009 | #34 | |
Well, back from vacation now. I put oil UV dye in the transmission. Drove to Bill's for a beer or two. The leaking oil is coming from the transmission. The UV dye is pretty neat. The oil has a slight tint to it, but as soon as I turned on the UV light, it glowed light green. I discovered that I had dripped it all over my bench as well. So I will be pulling the transmission soon to replace the input shaft seal. Jim Last edited by QB93Z; 09-03-2009 at 09:44 AM. |
09-02-2009 | #35 | |
Standing by waiting to assist the Captain! |
09-03-2009 | #36 | |
Rich
09-03-2009 | #37 |
Thanks Rich, definitely!
Darrin, think we can swap the tranny and replace your leaf spring in the same day? Let me know when you get your bushings. Better yet, get me a set too, I'll pay you back. Jim |
09-03-2009 | #38 | |
Glad you located the leak Jim. You got zippers on the tranny now? Take care, Jerry
09-04-2009 | #39 |
No zippers, but I did use ball-lock pins instead of bolts to secure the transmission.
Jim |
