Old 11-03-2009   #31
Default Re: Pulled the plenum, now what?
Dominic, I did the porting on this one....36+ all the way through......should breath pretty darn good. These were barely ported by vette doctors or whomever did the work. I am going to start doing another set soon.
Old 11-03-2009   #32
Just giving you another thumbs up!
Old 11-23-2009   #33
scholtmj
scholtmj's Avatar
Nice weather this weekend so I made some more progress:
New starter installed - used one for sale if someone wants it
New secondary port actuators installed
Re-polished the cam covers and installed stainless hardware
New Accel coils installed
Re-torqued breather box bolts - VD's used large amounts of RTV here
Painted top end with black wrinkle paint....have my doubts about durability
Installed IHs and started the vac hose maze!
Found out my HVAC box had 2 of the required 5 bolts installed
Couple Questions:
1) My replacement secondary actuator valve has a third tube on the 'back' whereas the stock unit only has the 2 facing the back of the block. Is this a 93-95 valve?
2) Cam cover bolts - passenger side went smooth sailing, drivers side not so much. VD's murdered 4 bolts when they reinstalled; I can't even get a T45 to grab. How does one go about removing these?
3) The third connector by the IH coolant temp sensor is for the AC? It's been too long since I took it apart!
Old 11-23-2009   #34
QB93Z
QB93Z's Avatar
Originally Posted by scholtmj View Post
Couple Questions:
3) Can you post a picture of the connector you are talking about?
1) Here is a picture of the Secondary System Actuator on my 1994 LT5. The third tube has a foam filter to keep debris from being sucked into the system when the Actuator turns off. I believe that the 1990 actuator is fucntionally the same and the later model should work fine for you.
Old 11-23-2009   #35
scholtmj
scholtmj's Avatar
That pictures helps a lot. I wonder when the design changed because I don't have the foam filter. I'll have to make one up.
Third connector is for AC that I put on tonight
Old 11-24-2009   #36
DDSLT5
Vette Doctors did it in the 90's but I don't have any information on the specs from them.
Bill Kirchhofer did the work.
DDSLT5 is offline   Reply With Quote
Old 12-02-2009   #37
scholtmj
scholtmj's Avatar
Progress:
Interesting mix of leaves, stones, cig butts and sticks in the radiator. Plenum will need to come off one more time, but I wanted to see how it looked. NAPA has sent me the wrong power steering line 3 times. Right box/number, wrong part. Once the PS stuff gets back on, throw on the samco hoses and put the radiator back in and I'm done...for a while.
Old 12-02-2009   #38
Hammer
Hammer's Avatar
Talking Re: Pulled the plenum, now what?
Believe it or not, you can still get them from GM.
93-95 ZR-1
GM #10159525
AC Delco #219-16
Old 03-04-2010   #39
scholtmj
scholtmj's Avatar
This looks interesting.....
Old 03-04-2010   #40
Jeffvette
Jeal camshafts eh?
End results....
