Old 04-01-2009   #31
diamond zr1
Default Re: What would cause this major catastrophe
wow Kurt/you could tell this story on believe it or not// makes my stories sound like fairy tails/
diamond zr1 is offline   Reply With Quote
Old 04-01-2009   #32
jonszr1
jonszr1's Avatar
that guy is a real piece of//////////work. you are handling this way better than i would. hopefully no one ever uses this guy again
Old 04-01-2009   #33
Jez, Kurt you are being civil about this, a reasonable response would have been to sue the guy...at least or just shoot him.
I really hate to bring this up, but as I was in on that group buy of the bearings. I would like to know for sure if there is a way to tell if the set I bought are okay to use? I was in from the Thread you had up at CF/ZR-1 section, where you let us pre-order before the bearings were made.
Is there an easy way for me to identify if I need to grind the block to use the set I bought?
Old 04-01-2009   #34
Aurora40
Aurora40's Avatar
Heheh, I was thinking the same thing. For the amount of money sunk into that jerk, it would be chump change to toss in a little more and have him killed...
Sorry to hear about that horrifically bad experience though!
Bob Saveland
Former owner of #2517
Old 04-01-2009   #35
Kevin
Kevin's Avatar
Thanks for telling the story Kurt, it was an interesting read
Old 04-01-2009   #36
limey
Tom,
The best way is to look at the main thrust bearing, on the back side, tell me if the radius is a 90 degree angle, or if it is a rolled "bend" The back side as in the part that sits on the lower crankcase girdle and not the face that touches the actual crank.
limey is offline   Reply With Quote
Old 04-01-2009   #37
Nick
Quite a story, Kurt. Hope you get something out of the motor salvage/parting out issue!
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
Old 04-01-2009   #38
USAFPILOT
USAFPILOT's Avatar
These story's reaffirm my thoughts of just leaving my engine stock, at least the bottom end. BUt I do like those big bore 415's. Maybe one day. At least I know who NOT to send it to.
Old 04-01-2009   #39
Jagdpanzer
Jagdpanzer's Avatar
Originally Posted by limey View Post
Tom,
Kurt,
Are the thrust bearings the only ones you had a problem with?
Old 04-01-2009   #40
Jeffvette
Kurt,
It's just the thrust bearing.
