#31 | |
![]() Join Date: Dec 2004
![]() Bob I hope you enjoy the fruits of your labor for a long time! Kudos man! ![]()
#32 |
i would be willing to bet you now have 25-30 more hp to your allready nice 368.i would have to go to the strip and see what she would do . enjoy
#33 |
Way too much Aluminum in there and whats that stick in the middle for
![]() Should look like this Rob ![]() Last edited by Polo-1; 05-16-2009 at 02:01 PM. |
#34 |
![]() Join Date: Jan 2004
Kevin you need to hurry up and get that monster running so we can see if bigger turns out to be better.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
#35 |
Finally got a chance to do some work on my car. Decided to CC the chambers to see how close they are. My budget method involves a clear piece of plexi in which I drilled a few holes, a large syringe and some trial and error to come up with consistent readings. All of them came in between 39 and 40cc except for one which was about 38.5cc. I did some clean-up work on the low chamber and brought it up above 39cc.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 Last edited by Locobob; 07-05-2009 at 07:27 PM. |
#36 |
Also after waffling over the idea for what seems like eternity I have decided to yank the secondarys out. For those that have done this procedure.... how in the hell do you pull the throttle shafts out??? Tried yanking on them with vice grips to no avail.
#37 |
Put the nut with washer back on and use 2 flat blades. You have get the alum steak spots cleaned out. 2 or 4 punches per throttle blade/bearing.
Mine cc'd 39.7 Looks good Rob ![]() |
#38 | |
![]() Join Date: Nov 2007
I recommend pulling the breather box, or you'll have trouble getting the throttle shafts out. Just loosen the AC pump (two bolts, if I recall) and move it out of the way. Then the box top comes off and removing the remaining throttle shafts is a "snap". And, another reason for removing the air breather box is so you can drive the freeze plugs into the bearing well! ![]() Speaking of freeze plugs, the next thing your gonna need is the right freeze plug. Pete suggested the Dorman 555-108, but they didn't fit, for some reason - too big. I went with the Dorman 555-110s, but had to splay them a bit (with a socket and a hammer) to make them fit snug. (I also sealed them with JB Weld, after degreasing the holes w/ brake cleaner.). (Marc H jotted down a note for me indicating the Dorman 555-011(?) would also work, but the dealer would have had to order them, so I went with the -110s on hand.) Piece o' cake, buddy! P. Last edited by Paul Workman; 07-06-2009 at 07:39 AM. |
#39 | |
![]() Join Date: Dec 2003
![]() Pete
#40 |
Thanks for the input guys. I've been trying the socket method but don't seem to have the right combination of stuff to get the job done, looks like a trip to the hardware store is in order.
Oh and thanks for the freeze plug info too, that was gonna be my next question.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 Last edited by Locobob; 07-06-2009 at 04:57 PM. |
