Old 10-29-2008   #1
Nick
Default '94 ZR-1 For Sale
For Sale:
1994 ZR-1 Torch Red/Light Beige #107. 75,000 miles, 2nd owner.
Painted top only; the car was not ordered with the transparent roof panel.
Purchased in February 2001 with 48,000 miles on the clock from the original owner.
Ported plenum and injector housings by Locobob, powder coated top end by Jeffvette, Stainless steel top end bolt kit.
Replaced:
Water Pump, 180 degree thermostat, coolant hoses. Clutch, flywheel and pilot bearing replaced at 50,000 miles. All new U-joints, rear wheel hubs/bearings and rear bushings at 70,000 miles.
Fluidyne radiator.
MSD coil packs, 8.5 mm plug wires, Denso iridium spark plugs.
Accel fuel injectors.
Coplon air duct reinforcement, K&N air filter.
Custom Haibeck chip.
Jeal 2 inch primary headers, Swain Tech thermal barrier coated, Random Tech metallilc substrate catalytic “bullet” converters, Corsa exhaust.
4.10 gears by DRM.
Boudreau C4 beam plates.
Hurst shifter and shifter knob.
Al Knoch seats done in 2007.
Michelin Pilot Sport Tires 275/40/17 front, 335/35/17 rear, 7,000 miles on the tires.
Baer slotted and cross drilled rotors, Hawk pads, powder coated J55 brake calipers.
Stainless steel brake lines by Earls.
DRM brake bias spring.
Standard C4 windshield.
Have all service and repair records and receipts.
Everything works, runs great. Dynos at 385 rwhp and 350 rwtq.
The modifications are all professionally and tastefully done correctly. Over $12,000 in modifications alone. Runs great, lots of fun!
Asking $24,500. E-mail: skedadl@aol.com
