Old 10-26-2008   #31
Default Re: Harmonic balancer
Ryan, thanks for sharing the light!
I suspected as much about the life span vs conditions. Thanks for your time.
Old 10-26-2008   #32
flyin ryan
flyin ryan's Avatar
most of the better SFI dampr's don't use rubber that you have to worry about & the ones that do, ATI, you can send back & have it re-built. usually every ten years or so, agian...depending. at least it's nice to have the re-build option open.
Old 04-12-2011   #33
digg101
I just received a new harmonic balancer made by Dorman in China and distributed by Rockauto. It appears to be the correct size but doesn't have the pins like my original. Does anyone now if thats a problem?
Thanks In advance
Kevin
digg101 is offline   Reply With Quote
Old 04-12-2011   #34
Thanks In advance
Kevin
No idea but if your looking for a low mile original for a 91 LMK. I have a spare in excellent shape
GOLDCYLON is online now   Reply With Quote
Old 04-12-2011   #35
Polo-1
Thanks In advance
Kevin
If you plan to use it, take it down to your local Machine Shop and make sure it's a zero balance damper. You wont be able to pin it like stock, so no more nickle balance trick.
Old 04-17-2011   #36
flyin ryan
flyin ryan's Avatar
X2...
Great advice
Old 10-23-2015   #37
Chris_32212
I just ordered one of these Dorman dampers. Its been a long time since I have been in the ZR-1 forum and I just had my car shipped to me after sitting in storage across the country for 3 years. It arrived with a coolant leak from the water pump and bad damper. So I guess I will put the cheep damper on and try it and send my original in to have it rebuilt. I eventually will need to pull the motor for a full rebuild (probably next winter) so I can put the rebuilt (original damper back on when the motor is out).
