#31 |
![]() Join Date: Jul 2005
What is the purpose of the Oil thermo., could it be for those folks in the mid west and eastern states that have those misable winters? Most folks that have a car that is driven hard install "oil coolers", yet they don't have thermostats, so why is there one on the ZR1?
Will be inspecting my cooling system thermostat this week as I don't believe I should be seeing high temps with the RD radiator no matter how hard the car is driven. Tyler keep posting those "nuggets" of info. Thanks, Jerry |
#32 | |
![]() Join Date: May 2005
Tyler |
#33 |
Tyler,
Thanks for the reply. I am still confused on the water bypass around the rad.; if the spring is cut why would you have to plug the bypass if the thermostat is what sends the water thru the bypass? Jerry |
#34 |
Jeff,
Where did you get a 170F thermostat, I find only 180F and of course the $100plus 160F? Jerry |
#35 | |
Tyler |
#36 |
randy woods he also sellls the under drive pullies . he also has a 165 therm that lets our cars run right at 180 . i got that one and love it . the 160 doesnt let the car go into closed loop.hes under specilized racing products . hope this helps
#37 |
John,
Do you have a web site address for Randy Woods? Tyler, If I cut the thermostat spring as indicated in the picture you posted will it allow for bypassing the Rad. when it's cold? I think I understand how it works at high RPM and thus cutting the spring will get rid of that problem but what about warm up, the water needs to go somewhere when the thermo is in the closed position? Jerry |
#38 |
go on the links page on the registry and find specialized racing products click that and your home
#39 | |
Tyler |
#40 |
Tyler,
If I read your reply correctly it seems to me that one could "plug" the bypass line and remove the thermostat? Thanks, Jerry |
