#31 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 10-01-2008 at 02:31 PM. |
#32 |
very nice update ,it seems like the issues are getting fixed very quickly . shows how much stainless works cares
#33 |
I installed my SW headers on my 90 Z two weeks ago.
Issues: 1. Oil dip stick bracket could not be bolted up. Factory spacer & bolt would not work. #4 exhaust tube interfered w/long bolt & spacer. Tried shortening bolt & spacer, could not get it to work. Ended up cutting the bracket off the dip stick tube, welded it back on to the oppisite side of tube & it fits w/SW bolt & no spacer. 2. Headers had EGR tube in passenger side header. Cut tube off flush & welded patch over hole. 3. Passenger side O2 sensor wiring was too short, made extension & installed. 4. Passenger side extension tube behind cat was too long, cut approximately an inch off both ends of extension. 5. I live in CA & the AIR injection system is required to pass smog. I removed the AIR tubes from my factory exhaust & installed (welded) them to the SW's. System sounds great, seat of the pants it pulls much stronger in upper rpm range (5-7,000). |
#34 | |
Thanks Don, helpful and productive comments ![]()
#35 | |
![]() Join Date: Dec 2003
They really do care and want to make sure you're happy. Is it perfect yet no but with everyones help we will make it perfect. Thanks!
ZR-1 Mom Founder ZR-1 Net Registry Founder ZR-1 Net NCM Lifetime Member |
#36 | |
#37 |
Just curious, what is different with this latest run of them? Haven't people been installing these for a few years successfully?
#38 | |
![]() Join Date: Jul 2006
thanks |
#39 |
![]() Join Date: Nov 2007
I bought my SW's just before the GP in Bowling Green at the Gathering in May. The install went well, but I needed the extensions on both sides. If you want to route the wires and have them out of the way with a professional install in mind, the extensions are needed. Not doubting Marc Haibeck..... you can get the driver side to plug in, but its still too tight in my opinion.
#40 |
Just a followup note regarding Stainless Works. Though they promised to get back to me regarding the EGR pipe extension, I haven't heard a word from their customer service or tech dept. Not good...
