Old 09-24-2008   #31
Jeffvette
Default Re: Baer brakes = INCREDIBLE stopping power!
Pics of hole?
Old 09-24-2008   #32
Aurora40
Aurora40's Avatar
Pics of hole?
Heheh, you really opened the door with that one!
I assume this is the hole you wanted to see:
Old 09-25-2008   #33
HIZNHRZ
I had similar thoughts but decided not to touch that one.
Old 10-03-2008   #34
Aurora40
Aurora40's Avatar
Default Brakes are on
The brakes are on. I bled them with a mity vac, and they are extremely soft. I'll have my wife step on the pedal and bleed them properly this weekend. Hopefully that will fix that.
Here's the banjo bolt Baer sent me compared to the OEM one:
And here they are installed:
A few lessons learned, of course don't do it without the right bolts. But also, don't use brake cleaner on these things. I got some non-chlorinated brake cleaner, the newer less earth killing ones. Mostly xylene, which is a paint thinner. I had some 3M stuff and some Valvoline stuff. The Valvoline stuff noticeably dulled and streaked the finish on the caliper. I'm not too concerned, I'd have preferred a rough aluminum finish like stock. But someone buying red ones or something might be a bit unhappy to find that out the hard way.
Old 10-03-2008   #35
xlr8nflorida
xlr8nflorida's Avatar
Default Re: Brakes are on
Sorry, just saw this thread or I would have chimed in. I have the Baer 6 piston 6S calipers on my ZR-1 and they are great. It did take some time to get them fitted though.
Old 10-04-2008   #36
Jagdpanzer
Jagdpanzer's Avatar
Looking real sharp Bob, the hard work and perseverance certainly paid off. Please give us a report on how well they perform.
You are real fortunate to have a wife who doesn't mind helping out when you run short of appendages when wrenching on the Z. I'm not so lucky, had to go out and get a set of speed bleeders instead.
Old 10-05-2008   #37
[quote=Aurora40;46018]I'll have my wife step on the pedal and bleed them properly this weekend. \[quote]
And.........
