08-31-2008 | #31 | |
Re: The dreaded water pump failure and a weekend project
08-31-2008 | #32 | |
I should have my car all together tonight. I will post up the pics of the install and the tool for everyone to take a gander at. GC
08-31-2008 | #33 | |
08-31-2008 | #34 | |
08-31-2008 | #35 |
Drive around those armadillo's though!! Man, they're like hitting a rock!
08-31-2008 | #36 |
The moose up here do serious damage to 18 wheelers, forget about passenger vehicles , it can get real ugly when Bruce the Moose decides he wants to cross the road .
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
08-31-2008 | #37 | |
if none have it I will let you know
08-31-2008 | #38 |
Heres a picture of the Corban clamp removers
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 08-31-2008 at 11:49 PM. |
08-31-2008 | #39 |
Ok completed.
You need to cut the rad shroud in order to get the shroud out. Its the only way unless you pull the AC lines and Oil Cooler lines. Dont worry I cleaned it after the install ! All together ! New Radiator
08-31-2008 | #40 |
I cut my shroud the same way when I did it too, but mine is coming back apart this winter to swap in the bottom breather air box
