Old 05-26-2008   #31
tccrab
tccrab's Avatar
Default Re: Jumped the gun still having stumbling issues
Originally Posted by -=Jeff=-
Update..
Injectors are FINE, Coils FINE..
I am working out a coupe things and don't want to speak too soon, but I thank I might almost have the issue resolved
Well?
Any luck?
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 05-26-2008   #32
Originally Posted by tccrab
Well?
Any luck?
not sure yet. Drove it Saturday and the issue did not show up..
Need to drive it again. not sure if I will get a chance today
Old 05-26-2008   #33
tccrab
tccrab's Avatar
Soo.....
What did you change/repair/fix/hit with hammer?
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 05-26-2008   #34
Soo.....
So far, I fixed a grounding issue with the O2 circuit
Old 05-26-2008   #35
bobbyhi
bobbyhi's Avatar
And did that fix the stumbing issue??
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 05-26-2008   #36
So far.. I think so..
Old 05-26-2008   #37
bobbyhi
bobbyhi's Avatar
What did you fix on the O2 sensor? Was the problem limited just one of the sensors or both??? Sorry for all of the questions but mine is doing basically the same thing I'm getting tired of just putting in parts, at a great expense, and not fixing the problem.
Bob Anderson
Founding Member #19
Old 05-26-2008   #38
bradslt5
jeff if i can ask what were the o2 sensors acting like that caused you to ck them.? i might have an intermittent issue with my 92.
Old 05-26-2008   #39
okay.. there are 2 grounds OUT of the ECM, one right, one left. both tie together to one ground lug. somewhere from the tied point to ground the line was open. I tapped a new wire in and grounded it that fixed the O2 issue.
with no ground from the ECM for the O2 s I was reading .45v ALL the time on BOTH sensors
Old 05-27-2008   #40
Nice catch! Kudos to ya Jeff!
