Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Member Rides
Old 01-10-2008   #31
flyin ryan
flyin ryan's Avatar
Default Re: WARNING:don't veiw if you don't like RED
i don't have that many good shots from the outside that give a good prespective & it's dark out & cold right now so instead i'll put up some shots as it was going up & maybe you'll get a better feel for it that way. this is from my backyard before the excavation started.this is around the middle of May. [IMG][/IMG]
Old 01-10-2008   #32
flyin ryan
flyin ryan's Avatar
excavation starting. the walk in door is my first addition five years ago. the big living room window up top on the left used to go straight down & was right on top of the old garage door. they called this a drive under garage.[IMG][/IMG]
Old 01-10-2008   #33
flyin ryan
flyin ryan's Avatar
excavation getting serious.[IMG][/IMG]
Old 01-10-2008   #34
flyin ryan
flyin ryan's Avatar
now it's at rough grade. if you notice my driveway on the left it's like 8"-8.5" thick. my neighbors on the right is standard 4". crazy! & i had to saw cut all of it. PIA. it's now approx. early June.[IMG][/IMG]
Old 01-10-2008   #35
flyin ryan
flyin ryan's Avatar
buddy of mine drilling pile holes. he built that machine himself. it's like a bob-cat on steroids.[IMG][/IMG]
Old 01-10-2008   #36
flyin ryan
flyin ryan's Avatar
i finished laying the rebar. another PIA. gradebeam is up.the chimney on the left was a problem to go around the whole time. it wasn't coming down.[IMG][/IMG]
Old 01-10-2008   #37
flyin ryan
flyin ryan's Avatar
floor & driveway poured. this was a big day at the time. the window on the left is where my walkway between the two sides are now[IMG][/IMG]
Old 01-10-2008   #38
flyin ryan
flyin ryan's Avatar
materials starting to show up. i didn't know it then but as it turned out i was shorted one truss out of that pile. you can guess how that went over trusses are 38' long. [IMG][/IMG]
Old 01-10-2008   #39
flyin ryan
flyin ryan's Avatar
starting to look like something. put those tree's in for some separation. it's getting toward the middle to end of Sept. [IMG][/IMG]
Old 01-10-2008   #40
flyin ryan
flyin ryan's Avatar
getting there[IMG][/IMG]
