Old 12-24-2007   #31
bradslt5
Default Re: self porting any done this?
did you also do the painting of the cam covers and plenum. i really like how the polishing and painting offset each other . what type of paint did you use /? that you for the well thought out post . merry christmas to you .
Old 12-25-2007   #32
Vette Guy
Vette Guy's Avatar
Thanks! I used PPG black base / clear coat with a flatening additive. I like the look of it much better than powder coat. In order to keep the plenum cool, I did use 1/4" spacers. I've been running it for almost 2 years without a problem. Good luck with your project!
Best Regards,
Vette Guy is offline   Reply With Quote
Old 12-25-2007   #33
bradslt5
thank you so much for the info on the paint . i like you like doing things myself . we all have to start sometime . and you have given me the inspiration to give this project a try. thankyou and merry xmas
Old 12-26-2007   #34
frank12
frank12's Avatar
Best Regards,
Congratulations, really impressive the beautiful and refined that is.
Some picture more, bigger and enlarged ideal?
Could you explain as making the polishing?
Frank
AM.C.C.C.
frank12 is offline   Reply With Quote
Old 01-05-2008   #35
Vette Guy
Vette Guy's Avatar
Frank
Frank,
Nothing special on polishing.... just lots of time on with a sander and polishing lathe. The water housings polish nice and quickly. You may encounter porosity in the plenum and air horn, which can either be sanded further or filled with some type of low heat aluminum weld. 3M red and blue fiber discs come in handy for getting into the small areas. No small project, but the results are well worth it. I don't have any photos from polishing... sorry.
Best Regards,
Old 01-05-2008   #36
Zr1 Destroyer
Zr1 Destroyer's Avatar
Gut that motha!!!!
IH's to match....
Zr1 Destroyer is offline   Reply With Quote
Old 01-05-2008   #37
Zr1 Destroyer
Kind of a cool pic....
Old 01-06-2008   #38
kenthompson
kenthompson's Avatar
You gotta let me know if that fits under the hood! Or what hood is on the beast.
1990 Grey/Black
Too many for the sig.
kenthompson is offline   Reply With Quote
Old 01-06-2008   #39
Jeffvette
NJ has a high rise hood.
Old 01-06-2008   #40
Zr1 Destroyer
Now if we could just get him put some coolant and a battery in it i'd be happy!!!
