Old 10-23-2007   #31
Harold Broerman
Default Re: acelleration problem?
hI ALL, WANT TO THANK ALL YOU GUYS FOR YOUR TIPS, IT TURNED OUT TO BE THE ECU. NOW THE CAR RUNS GREAT! ONE OTHER PROBLEM, ANY IDEAS ON TURNING OFF THE SERVICERIDE CONTROL? THANKS AGAIN, HAROLD
Harold Broerman is offline   Reply With Quote
Old 10-25-2007   #32
tccrab
tccrab's Avatar
Harold:
ServiceRideControl will come on if you start the car three times without moving it. Drive it down the block, then turn it off and restart it.
The light should then reset and go out.
If it stays on, you could be having problems with the FX3 shock actuator.
Here's a link to a site where you can buy replacement gears for the FX3.
http://captainzcnc.com/index.html
Where did you get the ECM and how much did it cost?
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 10-27-2007   #33
Harold Broerman
to tom c, a local auto parts store sent mine out to a rebuilder and cost 238.00. works fine! Harold
