1 Day Ago | #31 |
Re: 1992 Upper Radiator Shroud Removal
I didn't have an issue with mine. Make sure the intake assembly is in the correct orientation. Hose should just slip on.
Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige |
1 Day Ago | #32 |
Subfixer,
That's what's totally weird - the pump is bolted into position. Pump and hose match orientation in the pre-removal photo I took. Hose does slip on - hose starts sliding off as clamp is tightened. As Mystic said "patience" is not my virture. Thanks, Gary .... |
1 Day Ago | #33 |
1st try this morning and the hose stays on the air pump input when clamp tightened.
Go figure. Next step is installing the Heibeck Throttle Body Heat Bypass tube. Gary .... |
