#31 | |
![]() ![]() Join Date: Nov 2007
Anyway, you're not alone. I replaced my pumps and one of them was "kaput" out of the box. The pumps drew enough current, but the check valve on one was completely "shlect"; threw me for a loop at first until I put the pressure gauge on the fuel rail: then it was obvious something was very wrong (still!) with the pumps. (I pulled the pumps, and with a piece of rubber tubing, I blew pressure with my mouth against the check valve. Sure enough, one of the check valves passed air backward easy as you please.) Never assume!!!
#32 |
![]() Join Date: Apr 2016
I wonder if there's any way to get the check valves unstuck.
I got two brand new OEM with bad valves that I couldn't return. Haven't had the heart to throw them away because I keep thinking that someday someone will post "That's not a problem, you just................!" |
#33 |
![]() Join Date: Mar 2016
Hi guys, thanks for your help, the Z is up and running again!
#34 |
#35 |
Fairly new primary pump failed
#36 |
Yep! Several sources on failure rate Mean Time Before Failure (MTBF) refer to that phenomenon as "Infant Mortality". Just about everybody that endeavors to DIY repairs (me included) has fallen victim to installing a part, and just because it was a new part, assume it can't be the fault of the new part:
"It can't be the (whatever), cuz I just replaced it!" ![]()
