Old 07-10-2021   #31
Erik
Default Re: I guess it wouldn't be a ZR-1 without an oil leak.
The most common culprit for drips progressing to a puddle is the Low Oil Pressure Warning Light Switch, which is not easily visible, or to reach for that matter. It leaks oil through the switch, into the electrical connector. Remove the electrical connector and look for oil.
It is the picture on the left in the image below.
And Jerry comes through again. Took a couple of drives to get all the leftover oil off of it, but after the last 2 drives, the cardboard underneath shows not a drop anymore.
Thanks, Jerry!
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 07-10-2021   #32
1991 Corvette ZR-1
Question on the oil temp sensor for gauge readout: looks like a 90-91 can use the 92-95 oil temp sensor if the screw in bushing is changed out on the housing to one which accommodates the 92-95 version, correct? What size bushing is that? Asking because my needle barely lifts off the cold peg for oil temp and new 90-91 oil temp gauge sensors are pretty much extinct.
1991 Corvette ZR-1 is offline   Reply With Quote
Old 07-11-2021   #33
Marc Haibeck
The '92 - '95 sensor fits without the bushing.
Many people have replaced the oil temperature sensor and have been disappointed. The scale on the gauge is non-linear. When the needle is pointed at the second zero in the "100" on the gauge the oil temperature is about 180 degrees. That's normal.
Old 07-11-2021   #34
1991 Corvette ZR-1
Thanks, Marc!
