Old 04-28-2007   #31
93RubyZ
93RubyZ's Avatar
Default Re: What's the Mileage on your ZR-1(s)?
Originally Posted by rbidwell
I have 138,893 miles. SGC 368 done at around 134,000 while the engine was still running good. I have relaced both fuel pumps, injectors, vacuum pump, water pump, had radio repaired by Dr Don, replaced air conditioner compressor with later model and 134a. Had car repainted due to damage from shipping to SGC. Replaced started due to water getting in valley from water pump problem (one leaf covered the drain hole). I have no record as to problems before 132,000 miles as that is what the car had on it when I purchased it. I can tell you that it appears that the engine had never been apart.
Ron Bidwell
Ron, can you tell me what year your car is? Thanks!
Thanks again to all that are contributing data!!
93RubyZ is offline   Reply With Quote
Old 04-28-2007   #32
rbidwell
Sorry I didn't mention the year. It is a 1990 red/red.
Ron Bidwell
rbidwell is offline   Reply With Quote
Old 04-29-2007   #33
40th#381
I have an Anniversary Model with 39,700. on it.
Bought new July '93
40th#381 is offline   Reply With Quote
Old 04-29-2007   #34
93RubyZ
93RubyZ's Avatar
So far 88 ZR-1s have been accounted for. The highest mileage is 166,000 and the lowest is 37. Here is what the distribution looks like:
Old 04-29-2007   #35
jonszr1
jonszr1's Avatar
have 2 again just bought another red /blk one with 148k off original owner so cal car .have all paper work clutches 2and inj,coils other than that cool. blk car bought 68k now 3yrs later 133k clutch injsince i have had .before no clue but she still runs strong and only eats 1/4 qt of oil every 2k, when I change.
Old 05-01-2007   #36
flyin ryan
flyin ryan's Avatar
my 90 has 18,000 miles on it. when i bought it last July the service engine light was on. turned out to be a bad Derm module. CDN part no: 10094618...discontinued. sent the airbag computer to Airbag Systems in Allen, Texas. had it back & in the car in less than a week. no other previous issues that i know about.
my 95 has 9900 miles on it. it had the windshield replaced under GM warranty in 11/30/2000 with 9112 miles on it. i find this interesting. in service date was 12/05/1994 .
my 93 has 13,825 miles. haven't received the car yet but all the records i dug up indicate no problems under warranty or otherwise...yet.
Old 05-01-2007   #37
guinnessdood
guinnessdood's Avatar
My Red/Saddle 1990 #120 has 41,000 miles. It has numerous mods. Issues to date: Injectors were fine until I had them cleaned and tested...now they leak, Replaced the DIS module, replaced the ECM, replaced an intermittent wire to the crank sensor, new clutch, new front and rear wheel bearings, new steering rack, new Ron Davis radiator (old one blew because of the incorrect thermostat)....that's about it. Runs good!
guinnessdood is offline   Reply With Quote
Old 05-01-2007   #38
guinnessdood
Duplicate post
Old 05-01-2007   #39
John Boothby
John Boothby's Avatar
Mine is a 1990 #148 with 70,982 on the OD. The following have been replaced:
Clutch master & slave (twice); starter; A/C clutch; Injectors (with RC 205's); Plug wires; MAP; Secondary vac actuator; Front airbag sensors; Driver's side mirror switch.
Maintanence is performed: Oil at 3 mos; all other fluids at 12 mos.
Car is running great and driven twice a week or so.
John Boothby is offline   Reply With Quote
Old 05-02-2007   #40
TeK_NoiR
1990 - 39000 Miles and engine in best condition.
TeK_NoiR is offline   Reply With Quote
