Old 09-29-2020   #31
Prez1967
Default Re: Improving Steering Feel?
Originally Posted by Marc Haibeck View Post
Hi Erik. Several years ago I used Turn One to have a rack rebuilt. The rack still works perfectly. However it came back sort of dirty on the outside.
www.turnonesteering.com
I have emailed Turn One a number of times inquiring about their tuning abilities.
"for a higher steering effort that is consistent, we would have to make changes to the valve in the rack. The cost to do this would be $1,000 including the rebuild. You would have to dictate how much effort you would like.
For a performance oriented vehicle I would recommend upgrading the power steering pump as well. We can rebuild and upgrade your factory pump to reduce horsepower consumption, reduce fluid temperature and have a higher pressure capacity to handle the higher wheel loads that track use produces. The cost to rebuild and upgrade your pump would start at $200, if any hard parts need to be replaced then the cost would go up accordingly."
When there is a will, there is a way
Prez1967 is offline   Reply With Quote
Old 09-29-2020   #32
Erik
Very interesting. Thanks for sharing that. They do seem a knowledgeable company. True expertise is so hard to find.
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 09-29-2020   #33
Erik
I don't think anyone has mentioned it, but something like the R-D Racing Camber Brace should help the feel too.
1990 ZR-1 # 996
Old 09-29-2020   #34
tf95ZR1
tf95ZR1's Avatar
Yes, but it makes working on the front of the engine, or adjusting
the front end alignment a real PITA!
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 10-02-2020   #35
Erik
Can't have everything.
1990 ZR-1 # 996
