Old 03-27-2020   #31
Corvette95
Corvette95's Avatar
Default Re: virus projects?
from the action center...I spoke with Jim Ingle recently who was a Corvette Powertrain Engineer and did a lot of the develoment testing on the ZR-1s. Most of the GM performance figures you see for the various years on the ZR-1 were established by him. I asked him about the use of steel half shafts and why the switch to aluminum. This is what he had to say:
"We had difficulties staying in the EPA weight class we needed to be in to avoid paying gas guzzler tax. Of course, this was prompted by crash and bumper standards that resulted in weight increases. The aluminum axles were part of the weight reductions used." -- Jim Ingle
The half-shaft was changed early in the 1990 model year starting with VIN # 800621.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 03-28-2020   #32
billschroeder5842
billschroeder5842's Avatar
This weekend, I'll be an *** Man, just like Cosmo Cramer.
I'm putting my rear end up and doing a combo detail, lube suspension, brakes and general crawl around. I do have that frequent "click/snap" comking from the rear that I thought I licked. While the tires are off I'll take the spindle nut off and re torque to +10 and see if that makes a difference.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 03-28-2020   #33
ABBEZR1
Originally Posted by Corvette95 View Post
Did a clean up on the engine and suspension before the final part of the top end pull tomorrow.... did find a neat sticker on the half shafts.... very early 90.....
I didn't have any stickers on my shafts but a assembly worker had fun with my 90 #946 they drew with a permanent marker on the shafts ZR-1 with a smiley face ....They drew another one with a white china marker in the spare tire carrier..
Steve
_______________________
1990 Bright Red/Black #946
B and B X-Pipe
Stainless Works Long Tube Headers
Cat delete
49th Street Rockers
Haibeck Chip and Tune
ABBEZR1 is offline   Reply With Quote
Old 03-28-2020   #34
Don't know what your "click-snap' is, and this may not be the same, but I had a noise/clunk in the rear of my '95 that was heard whenever I hit a bump or backed out of my inclined driveway. Marc H. changed the sway bar bushings and it went away. The sway bar bushings looked and felt OK to him but we did it anyway and it worked. --Bob
Old 03-30-2020   #35
Corvette95
Corvette95's Avatar
Got my new fuel pumps together along with Carter's Y-Adapter. The zip ties in case you wonder, are to prevent wire chaffing.
Old 04-05-2020   #36
Demps
Demps's Avatar
My coilovers have settled a bit with time. I decided to raise the rear slightly (0.175” at spring retainer). Biggest thing it accomplished was my daughters wanted to go for a ride. We managed to take rides in a 415, pictured car that I raised with a cammed 350 & 4.30 gears, a ported engine HPDE car, and a totally stock car.
This Virus pandemic is scary. It has caused me to slow down a little on the weekends and enjoy us. We are usually running 90 to nothing entertaining everyone. Yesterday was near perfect as I got to enjoy the cars with my daughters. I’ve been debating on diversifying my hobby but every time I spend time with these ZR-1s I fall for them all over again. Folks make fun of me for having the same thing but everyone is different.
Hope everyone is staying safe.
Ted
Old 04-05-2020   #37
Curtis
Mine was making same noise and is gone as of about 6pm today.... new rear sway bar bushings and endlink bushings
Washed 90 lbs of dirt and sand from the tire carrier and found what looked like bean sprouts growing that or some huge grass seeds
While soaked went ahead and pressure washed everything back there and wet sanded the borla’s and pipes from resonator back..., inside of rear wheels etc etc.... maybe by august if I work on it every day I’ll get all the bushings changed to poly.....
Wish I had a flat driveway so wanting to lower the car ....
Did a few test hits and at a 3800 hit in first dead hooks and only barks second and barks 3rd.... maybe locked down but can always go for a drive
Tomorrow is the attack on the front sway bars if my back gives me permission
Saw 2 other c7’s doing same as me....just tooling around loving the car
Curtis is offline   Reply With Quote
Old 04-05-2020   #38
Originally Posted by 902066 View Post
Since I have a lot of time on my hands, I am working on stopping an oil leak at the "oil pressure regulating valve cover plate". I've been reading the helpful hints in the solutions section, and am ready to jack the engine up a couple of inches to see if that makes the bolts more excess able. If anyone has more helpful tips, I'm all ears!
Post 20 - Potential Oil Leaks and the OPRV Cover Plate
Old 04-07-2020   #39
Blownrunner
does your cruise control work?
Blownrunner is offline   Reply With Quote
Old 04-19-2020   #40
Curtis
Called up Mr Lingenfelter’s guys about fuel pumps but was told walbro has been incognito for a few weeks so called in favors and ended up with two 255 walbro’s so put them in yesterday
No leaks no smells and car seems to run a bit better.....
Car has one of Marc’s chips, new k&n and old school borla cat back systems
filmed by 160 lb camera guy I picked up on the Mexico border and a fresh full tank of 93..... know it’s slow but makes me happy
https://drive.google.com/file/d/180S...zn4lDcRyy/view
Let me know what you guys think of how it’s running.....thanks
