03-02-2020 | #31 |
Re: Corsa X-Pipe
The 454 would fit in your car 🚙 and save the LT5 for when you are ready to sale your car in an other twenty five years!
03-02-2020 | #32 | |
Re: Corsa X-Pipe
The 454 peaked at 6100 where as a modded 350 LT5 peaks at 6700+ RPM. Pete
03-03-2020 | #33 | |
Re: Corsa X-Pipe
Phil, IIRC ur running 4.10s w 19” in back. So cruise at about 75-80mph is coming in at 1900-2100rpm. Same as mine is currently. Part of taming drone has to do w the tune itself. The better and more spot on it is, the sweeter the exhaust note. The richer the tune, the more likely u’ll have drone especially as MAP increases, ie inclines. Which is why I like to tune the cruising areas of the VE tables just just slightly lean, say a 130-131 BLM. My exhaust consists of 1 7/8” coated Watsons, w 3” ID pipe into Stainless Works X-pipe(no bafflling), then into 3”ID DynoMax Ultraflo dual outlet mufflers topped off w C6Z06 NPP tips(thx Al)Normally run w one outlet switched to Closed.
03-03-2020 | #34 |
Re: Corsa X-Pipe
I will also add is that Drone is relative.. what some might not hear or feel as drone, might affect others.. I had Corsa on my 1990 with headers and cats, there was no drone, but at WOT I did not like it.. cruising around was much better (to me). Now I have a Stock LT4 system behind my Headers and Cats. if I were to change anything I would swap out the mufflers, but the LT4 system is the Highest flow stock C4 system out there. I am finally at the point where I am just leaving it alone
03-05-2020 | #35 | |
Re: Corsa X-Pipe
03-05-2020 | #36 |
Re: Corsa X-Pipe
Funny you have pictures of the cutouts installed on your system?
03-05-2020 | #37 |
Re: Corsa X-Pipe
Yes, but need to find them.
03-05-2020 | #38 |
Re: Corsa X-Pipe
Whenever.. Curious, not that I will get to it anytime soon.. but I like the idea
03-05-2020 | #39 | |
Re: Corsa X-Pipe
Cut-Out Pics Last edited by Gunny; 03-05-2020 at 12:24 PM. |
03-06-2020 | #40 | |
Re: Corsa X-Pipe
