Old 12-02-2019   #31
RubyredEd
Default Re: 93 Starter Not Engaging
Try another
RubyredEd is offline   Reply With Quote
Old 12-02-2019   #32
RubyredEd
Another
Old 12-02-2019   #33
RubyredEd
Last one
Old 12-02-2019   #34
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
According to the 93 factory service manual there is a fuse panel up there that contains the theft fuse.
While I have never had to search for it, the info came from the FSM.
Perhaps use a mirror and flashlight.
Marty
Old 12-02-2019   #35
On a 91'
Old 12-02-2019   #36
RubyredEd
Thanks, will try again tomorrow!
Old 12-06-2019   #37
DRM500RUBYZR-1
Any updates?
Marty
Old 12-06-2019   #38
RubyredEd
Just got back from 3 days away and didn't have a chance to try again. Looks like I will have to try to get it done tomorrow. Thanks for checking in, I certainly can use your help!
Old 12-07-2019   #39
karlaw
Originally Posted by RubyredEd View Post
Took a look and there are 2 looms. I was able to open the larger and did not see any purple wires that were even close to 10 or 12 gauge. I also did not see any voltage drop while depressing clutch or attempting to start. Any one have a picture of where this wire is?
karlaw is offline   Reply With Quote
Old 12-07-2019   #40
karlaw
Originally Posted by Marc Haibeck View Post
I have encountered starters with stuck solenoid pistons after storage. I have found that if the starter can be activated one time, it will operate normally thereafter.
One method is what I call the Wakeup Call to the starter. The procedure is on page five of this document.
http://www.zr1specialist.com/HAT%20W...20problems.htm
The easy place to find the purple wire is on the clutch switch connector under the dash.
Another method is to vibrate the starter. The starter can be struck with a hammer. With a focused light look down next to the power brake booster. You will be able to see the corner of the coil pack. Under that is the starter. Use a 18" long 1/2" steel rod. Place it on the corner of the starter. Have a helper hold the ignition key to start. At the same time strike the steel rod.
