Old 02-28-2020   #31
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: Garage lifts and doing damage to suspension
Great Idea!!!
Marty
Old 03-15-2020   #32
Vette Guy
Vette Guy's Avatar
Awesome Hans! I forgot all about the airbag lift. Jim Voter has a piece of I-Beam which he uses with an airbag to slide under the diff, and raise the rear. The part slides right between the exhaust pipes, and is rubber padded. Once lifted, the jack stands go right under.
I have a Bandpak HD-9 and 2 narrower HD-9STs. The larger HD-9 is what I use for all my work. I have 2 bridges that I can jack from, but really wanted a bridge jack. They are outrageously expensive from Bendpak, and having seen problems with the air jacks, looked for something else. I purchased a Quality Lifts rolling bridge jack QRJ04H 4,500 lb from NAPA. It is a manual hand pump and I love it. You need to check your inner rail height before purchasing. I didn’t. What I found is that it sits about 2 inches below the bottom of the lift, and touches the floor first. While I didn’t like that at all, the awesome part is that it barely runs over the surface of the ramps and allows movement of the jack freely, even a super lowered car. Even better, I caught a NAPA sale and purchased it for under $700. Well worth every penny.
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 03-15-2020   #33
Originally Posted by Ccmano View Post
For those with 4 post drive on lifts, I discovered a quick and inexpensive way to lift the car on the lift. I bought a 2 bag air jack on Amazon for about $100. It’s the perfect height to slide under the Z and lifts the car in seconds so a jack stand can be placed under the frame. No more pumping a hydraulic jack! Also works to lift from the center if you have jack bridge (but no jack). They are also on EBay. Only the 2 bag will fit under the frame. The 3 bag is too tall. Take a look.
H
That is pretty damn cool
Old 03-16-2020   #34
lfalzarano
Great post!
Old 05-01-2020   #35
erikszr1
lots of great info here, but myself as a technician for 35 plus years would only want a 2 post lift. anything else for me gets in the way. unless your just storing cars and cleaning ect.
[/SIGPIC]
erikszr1 is offline   Reply With Quote
