Old 05-12-2019   #31
Ccmano
Ccmano's Avatar
Default Re: Lean at high rpm
Originally Posted by ALLTHECAMS View Post
Thanks. Maybe a dumb question but which one is the primary? The lower one?
Sent from my XT1710-02 using Tapatalk
The upper one is primary...
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 05-12-2019   #32
ALLTHECAMS
ALLTHECAMS's Avatar
H
Thanks. Glad I asked.
1991 ZR-1 #520 Arctic White/Gray
ALLTHECAMS is offline   Reply With Quote
Old 05-13-2019   #33
ALLTHECAMS
ALLTHECAMS's Avatar
Took it apart and primary pump hose had slipped off. Amp draw was low because pump(s) were freewheeling. I tightened them as tight as I dare but I wish Airtex pumps had nipples on them.
Old 05-14-2019   #34
Daryl (aka "GOLD CYLON") had some jumpers (links) made up for emergencies that when inserted would swap the pumps electrically. That way you wouldn't be stranded somewhere if the primary pump failed...and there have been a few instances where that DID happen.
With a couple connectors and some 'hook-up' wire you could make your own, if you're handy with tools and a soldering gun. Just swap the wires (on you DIY jumper) so that the secondary pump is powered by the primary wire coming from the stock wire harness. (I keep my jumper in the glove box for emergencies.)
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
