#31 | |
#32 |
#33 |
![]() Join Date: Jun 2005
What model year is this car?
#34 |
#35 | |
I'm thinking there still is a problem with a bad connection at the memcal connector in the ECM. I base that on the fact that the code 14 went away after cleaning the ECM connections which tends to reinforce the idea that the problem is a bad connection that became bad during the washing process. Before I'd spend the money on a new cal chip, I'd go buy yourself a spray can of electrical contact cleaner. Usually you can find that at an electronics supply store or an industrial hardware store but maybe even Lowes or HomeDepot. Unplug the four ECM connectors and spray contact cleaner into both the connectors and the ECM sockets. Then carefully plug and unplug each connection a couple of times. Finally, spray contact cleaner on the connectors and sockets, again, and let the cleaner air dry away for several seconds, then reconnect all four connectors. Then, remove the cal chip, spray contact cleaner onto the socket in the ECM and on the bottom of the chip. Then carefully install and remove the chip a couple of times. Finally spray contact cleaner on the socket and the chip again, let them dry then reinstall the chip. Clear codes and road test. If code 41 resets, replace the cal chip. If the code still persists, replace the ECM.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 05-05-2019 at 02:22 PM. |
#36 |
Hib,
I think he was going to get a performance upgrade cal from Marc Haibeck anyway. This way he’ll kill 2 birds ... |
#37 |
New MH chip on the way.
I cleaned the contacts once already with some 99% isopropyl. I do have some DeOxit for my audio equipment, I’ll give that a try just like you describe. There’s a lot dielectric grease on everything, makes it hard to clean. If this new chip fails to get rid of this code, anyone out there have a working ECM for sale, just in case I need it? |
#38 |
If u r checking codes, the first one u should get is a
Code 12 which is an ECM self test. If u get that, the ECM is ok. |
#39 | |
To you, that indicates a healthy ECM? |
#40 |
From what u are describing, the codes u r getting are on the cluster and from the CCM, nit the ECM. ECM CODES will flash on the DIC.
