04-25-2020 | #31 |
Re: Alternator upgrade
Second chance do you have a post/ write up of the Spal fan install?
04-25-2020 | #32 | |
https://www.zr1.net/forum/showthread.php?t=30609 |
05-15-2020 | #33 |
Did you run the additional 8 gauge wire to the alternator? If so where does the wire terminate? Thanks for the thread! I already got the altenator you recommended
05-15-2020 | #34 |
If you are asking Secondchance, he said he did in his first post
05-15-2020 | #35 |
Is there any advantage to adding the 8 gauge and 18 gauge for the fan motor without installing a higher amp unit? I have a brand new stock one form Jerrys already installed.... exercise in futility?
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
05-15-2020 | #36 | |
Thicker wire alone, may not have much effect. Last edited by secondchance; 05-15-2020 at 06:18 PM. |
05-15-2020 | #37 |
Actually the thicker the wire the LESS resistance but the thicker the wire the more current can get pushed through without burning it up.. Heat is generated by the resistance
05-15-2020 | #38 |
[QUOTE=-=Jeff=-;309294]Actually the thicker the wire the LESS resistance but the thicker the wire the more current can get pushed through without burning it up.. Heat is generated by the resistance[/QUOTE
Without alternator with higher output, what effect would larger ga wire have on fan motor? |
05-15-2020 | #39 |
More power/current flow to the fans. So the fans would benefit of the larger wiring as there will be less power drop at the fan
05-15-2020 | #40 |
